BERGFALKE IV CABRIO 1:4.7 SCALE**
Re: BERGFALKE IV CABRIO 1:4.7 SCALE
Depends which weather forecast you look at
It's often best to make up the combined brass boxes for the fuselage with the wings joined together as the epoxy cures. The boxes extend into the wing root fairing and are trimmed off at the end of the process...
The ailerons are fairly simple: just built over the plan. Then it's time to fettle the winglets. (These at least are scale, as there is one Bergfalke 4 on the 'net fitted with them)
Now for my favourite bit: the airbrakes...
Continuing with the airbrake saga...
That's the airframe pretty much complete...
In a last-minute decision I decided to fit the spare Turnigy G32 that I had lying about. (A wise move as it later turned out)
- Cliff Evans
And it was all going so well!!
I've used my usual finishing method: Solartex and 2k paint on the fuselage, and HK film on the flying surfaces...
- Cliff Evans
Nice Chris.
