Some time ago I designed a 50% PWS101 vintage glider for a New Zealand friend.
two kits were cut localy. Due to serious illnes, moving house and running a business building was delayed.
Now one kit build is underway
Attached a picture of the stabilizer/elevator in progress. this has a 1.5 m span
For those interested some PDF files with a model 3view and dimensions, Assembly details and notes I made for potential builders so you know were you are in for.
The short kit and drawings are available from Cliff Evans
1/2 scale (50%) PWS101
- Attachments
- ASSEMBLY-A3.pdf
- (309.49 KiB) Downloaded 125 times
- PWS-101-3VIEW-A3.pdf
- (301.2 KiB) Downloaded 112 times
- PWS-BUILDING NOTES.pdf
- (405.29 KiB) Downloaded 87 times
