CM 8/13
patte de loup
CM 8/13
Post by patte de loup »
I have started my new acrobatic glider last April, hopping it will be finished in next May for the annual GPR meeting in Menez Hom. Huge challenge when, you are still in activity and normanlly I make 2 years for building one :lol:
The real one is stored at Anger Macé Museum and mine will be at 1/3 scale with 4.5 meter of wingspan
Pat'
patte de loup
Re: CM 8/13
first step, machining of the fuselage frame
Pat'
patte de loup
Re: CM 8/13
Frames are now on the primitive jig and stringers are on going for glueing ( pin 8 x 8 ).
Re: CM 8/13
Nice looking glider, Pat, not seen that one before...
Re: CM 8/13
CM8.13 Info.pdf
(194.11 KiB) Downloaded 149 times
patte de loup
Re: CM 8/13
Finish to put all stringers in place an glue the fixed panel of the rudder.
patte de loup
Re: CM 8/13
Now, is time for planking with 30/10 balsa sheet of the upper side .
patte de loup
Re: CM 8/13
The fuse is enough strong to be remove from the jig and move on to lower side
Pat'
john greenfield
Re: CM 8/13
Post by john greenfield »
patte de loup wrote: 02 Jan 2022, 17:28 Now, is time for planking with 30/10 balsa sheet of the upper side .
Patte
Can you explain what 30/10 balsa is please?
patte de loup
Re: CM 8/13
john greenfield wrote: 11 Jan 2022, 09:34
Patte
John,
I cut strips of 10 mm width from balsa sheet of 3mm thick for planking the fuse. Same method for making a hull of boat.
( sorry my english is little poor )
