OK, the only situation where you might not need F6a is when you can guarantee that every landing will be perfect...! Otherwise, a crosswind landing is liable to pull the joiner box off the top of the fuselage. (Don't ask me how I know) Fitting F6a, with its Ali bracket, allows the bracket bolted to the wing joiner box to spread the landing loads down through F6a to the horizontal stringers below...
(Note: the attached photo is from the build of the smaller version of the Topaze)
Wing joiner
Re: Wing joiner
Ok thanks I'll definitely need it in place then, can you confirm former f6a is just a copy of f6.
Re: Wing joiner
No, it's a blend of F6 & F7. You should have a copy of it with the rest of the info, but I'll attach it here as well. This was a mod that occurred well after the plan was published, which is why it's not on the original drawing...
- Attachments
- F6a RETRO-FITTED FUSELAGE FORMER.pdf
- (270.1 KiB) Downloaded 69 times
Re: Wing joiner
Thank you Chrischris williams wrote: ↑06 Jan 2022, 23:39 No, it's a blend of F6 & F7. You should have a copy of it with the rest of the info, but I'll attach it here as well. This was a mod that occurred well after the plan was published, which is why it's not on the original drawing...
Re: Wing joiner
Hi Chris can you just confirm what scale this f6a retro fit former is actually for as I might have got my wires crossed
Re: Wing joiner
That's for the 3.5 scale version...
Re: Wing joiner
Ah ok I've got the 1.3.5 scale 4.4m. Think this is where I've got confused, is the retro fit needed for this size
Re: Wing joiner
Yep, it's for both sizes...
Re: Wing joiner
Cool I'll try and not bother you anymore
But can't promise
But can't promise
