Penrose Pegasus
Re: Penrose Pegasus
Adam C wrote: 22 Feb 2022, 20:21 Why Mr Cole I do declare you are persuasive but alas the best I can now do is fit a basic hook. Would that suffice?
No, not really. I will e-mail you a plan...
8-) 8-) 8-) 8-)
Trevor
Re: Penrose Pegasus
Post by Trevor »
I'm sure Barry will offer you a great approach but, if it helps, I did do a similar retrofit on my AV36 - after it had already had a motor retrofitted!
http://www.bartonhewsons.uk/home/modelf ... lease.html
Re: Penrose Pegasus
All you need is the Smallpiece Super-Separator...
Re: Penrose Pegasus
There you go.No excuses now.
E-mail sent.
:D :D :D :D
Adam C
Re: Penrose Pegasus
Post by Adam C »
Barry,
Lovely plan but too late now for me. I'm not able to fit it in with all the electrics in place. Next time...
Adam C
Re: Penrose Pegasus
Post by Adam C »
OK slow progress as there's been flying weather.
Rear of ribs added to spar. Changes TE so ribs not just butt glued to spruce LE. Full length 1/64ply top and bottom encapsulates the lot and is very strong.
Re: Penrose Pegasus
THERE HAS???, WHERE??
Adam C
Re: Penrose Pegasus
Post by Adam C »
Nice few days of easterly winds, ideal for hms Mercury near petersfield
Adam C
Re: Penrose Pegasus
Post by Adam C »
Centre section almost done and sitting at 450g.. TE encapsulated in strips of 1/64ply quite rigid compared to the original design. Centre section sheeted as well for piece of mind as there isn't a lot of meat on the bone round that area. Will do underside as well in the middle.
Brass joiners and premade strut fixings on ply plates. They can be installed after sheeting. Need to now build the wing tips.
Adam C
Re: Penrose Pegasus
Post by Adam C »
Centre section sheeted on top and aluminium fittings glued in place. Remarkably accurate fitting which isn't my hallmark. I'm happy with a 3mm error but everything is spot on.
Struts next but not before I do the sheeting under the wing. Outer sheeting wil be done once the outer panels are completed so any joining issues are easy to address
