Robin Slight - Prost restoration.
All non-scale topis should go in here for discussion.
Jon_S
Re: Robin Slight - Prost restoration.
Post by Jon_S »
The rudder was falling apart. Either damaged from flying or damaged while laying around the garage/workshop for many years.
The rudder was made from sheet ribs and a leading edge section.
I dismantled the old rudder to get the profile for the ribs.
Infact I managed to get the ribs out of the old rudder and used them in the new rudder.
Ribs were from 1/8th soft balsa. Leading edge is 1/4” medium and then I used some
Left over leading edge section that was then sanded to shape.
Covered with white oracover and then a closed loop control added.
Hope drilled in the top for the live hinge and brass tube fitted in the base for a piano wire keeper.
Turned out nice.
Jon_S
Post by Jon_S »
Small bit of tidying up to
Do with the fuselage radio installation.
I need to make a new wiring loom as I chucked the old one away.
New closed loop wire fitted that has yet to be tensioned until the full install has been completed.
I can now divert attention to the wing.
Jon_S
Post by Jon_S »
A bit of a break to build a new work bench and do some house hood chores.
Working on the wings.
Now the servos were old and mostly crap and slow.
I had to cut off the servo covers that were stuck down with take adhesive.
Prosing out the old servos, I found out that they were stuck in with bathroom sealant. That’s never going to end well.
Anyway after some prising I managed to get the old wing servos out make good the holes and then start fettling the new servos.
Brian Sharp
Post by Brian Sharp »
It is great to see you doing this resto on Robin’s aircraft. I flew against him on many occasions and really enjoyed his company’ he was a real gentleman. His aircraft were always immaculate, and it is sad to see them in such poor condition. I hope you are able to finish this model and enjoy flying it successfully in the future.
Brian S.
Jon_S
Post by Jon_S »
Cheers Brian.
Hopefully I’ll get this model back in the air. Was too good to Chuck in the bin.
