BJ-1 DUSTER**
BJ-1 DUSTER**
A short thread for the 5th scale version of my Duster plan...
DG1000
Re: BJ-1 DUSTER
Post by DG1000 »
Chris,
Thank you for putting these photos on here, will keep my build thread up to date.
Geoff
Re: BJ-1 DUSTER
Here are all the parts...as usual, check the print-out against the plan...
C2.pdf
(233.61 KiB) Downloaded 291 times
F1-4.pdf
(251.46 KiB) Downloaded 222 times
F5 H1.pdf
(241.35 KiB) Downloaded 207 times
F6 H2.pdf
(236.81 KiB) Downloaded 215 times
F7-10.pdf
(236.63 KiB) Downloaded 200 times
FIN-RUDDER.pdf
(249.3 KiB) Downloaded 242 times
FRONT FAIRING TEMPLATE.pdf
(238.39 KiB) Downloaded 209 times
H3.pdf
(227.76 KiB) Downloaded 185 times
H4 H5.pdf
(222.4 KiB) Downloaded 190 times
MISC 2.pdf
(242.11 KiB) Downloaded 199 times
MISC.pdf
(262.52 KiB) Downloaded 197 times
R1.pdf
(314.13 KiB) Downloaded 189 times
R1-12.pdf
(294.27 KiB) Downloaded 193 times
R2-12.pdf
(254.12 KiB) Downloaded 194 times
REAR FAIRING TEMPLATE.pdf
(249.53 KiB) Downloaded 200 times
WING JIG SUPPORTS ETC.pdf
(264.78 KiB) Downloaded 225 times
DG1000
Re: BJ-1 DUSTER
Post by DG1000 »
Chris,
Again many thanks for making these available.
Geoff
Re: BJ-1 DUSTER
Continuing...
Re: BJ-1 DUSTER
Finishing off the tail and starting on the wings...
Re: BJ-1 DUSTER
The top sheeting will be added after the wing centre section is laid on to the wing support jigs
Re: BJ-1 DUSTER
Now for the outer wing panels...
Re: BJ-1 DUSTER
More on the outer wing panels...
Re: BJ-1 DUSTER
Sorting the TE brakes and wing tip... I made up the up-turned tips of the full-size, but in comparison to Smallpiece's conventional tips, there seems to be a slight reduction in beneficial stall characteristics, so one up to the Wookie
