SZD - 36 Cobra 15 1:3 scale
First rib, which will be later glued to the fuselage is taped to the wing.
Just to hold it in place, I put microbaloon+epoxy in some places.
Once hardened, I sealed the gap on the lower side, then poured in some thinner mix of microbaloon+epoxy and thicker one at the end.
Roughly sanded in shape. Final touches will be done when wings are finished, just before painting.
Looking good...
