[quote=MarkDev post_id=14977 time=1508178902 user_id=267]
How's everyone getting on with the faster frame rate setting on this rx?
M
[/quote]
Not found the time to do the update yet. Works fine with digital servos but I didn't realise what the problem was until Barry kindly messaged me otherwise I may well have tried to return these receivers....... and of course the one model I want to use first has analogue servos!!
Life used to be so much simpler with 6 (I think) single colour crystals, splits if you dare, simple servo choice, deacs and a pennant on the end of the aerial to tell you which way the wind was blowing.......
MarkDev wrote: ↑18 Oct 2017, 16:05
Barry, While I was in that glider page I saw that one of my X series rx is also running at 9m/s on 1-8 channels, fortunately I have digital servos in that one. This is one of the X series rx that you flashed with EU LBT last year. I'll check the others just to be sure.
As I used your downloaded software yours might be the same?
M
Mark, That is not the same issue, what you see on the Tx is 9mS for up to 8 Ch, and over 8 at 18mS, that is the transmission rate.
The bit that we are interested in is the rate that each servo is updated, and for the X series it is 18Ms, so panic not, little seaside dweller.
Life was much easier when we did not know what was going on.
chaps, having trouble getting my G-rx8 to bind (it worked first time and went blue) now all I get is either a solid red light or a flashing red light and no bind either way.
Tried other x series receivers with success, flashed the firmware on frsky's advice - any thoughts?
Barry,
Did I tell you that I have a nice Graupner Hott Transmitter and Receiver which works all of the time and plays nice tunes as well.
For Sale at £225 with 2 x 12 ch Receivers. You just turn it on and go flying.
