Minimoa MO2a -Chris Williams plan and Cliff Evans kit
mick a
Re: minimoa mo2a -chris williams plan and cliff evans kit
Post by mick a » 08 Nov 2018, 14:43
thanks Chris
will make a note of that
does the main spar still taper from the wing join (12mm-6mm) or does that start from 13 as well ?
thanks again
mick
Post by chris williams » 08 Nov 2018, 14:57
The main spars taper from the gull join, Mick...
cw
mick a
Post by mick a » 11 Nov 2018, 10:13
a bit more done today
mick a
Post by mick a » 07 Dec 2018, 20:06
bit more done today
starting on the canopy , but seem to have gone wrong again !!!
the formers don’t seem to fit at all , 20mm short in width , has anyone got any ideas or methods how to get an even curve
to match front former
have tried to copy front and cut down - didn’t work
any ideas greatly appreciated
thanks mick
pics might help explain
Post by chris williams » 08 Dec 2018, 00:39
Here are the all the frames for the canopies, Mick...check your parts against them?
F6s F8b F8c.pdf
(225.38 KiB) Downloaded 61 times
FRAMES (1).pdf
(239.48 KiB) Downloaded 47 times
FRAMES (2).pdf
(241.43 KiB) Downloaded 51 times
mick a
Post by mick a » 08 Dec 2018, 07:14
thanks Chris
will try that ,
mick a
Post by mick a » 10 Dec 2018, 18:53
Does anyone want a minimoa to finish off
have give up with it , just to difficult, seem to be having difficulty in every step
tailplane, rudder , inner wings and fuse all done
just canopy and outer wings to be finished
Post by chris williams » 10 Dec 2018, 21:45
It has to be said Mick, the MO2a canopies are the most complicated canopies I've ever had to make (and then you have to paint them)...
mick a
Post by mick a » 10 Dec 2018, 22:34
hi Chris
i know what you mean, managed the front section and rear section - just a cannot get the middle to fit at all, either to small too big or wrong curve
it’s a lovely plane but just loosing the will to finish it ....
hopefully will get the enthusiasm back soon, as love to build but seem to be doing everything 3/4 times
OH the joys of modelling ..... lol
Post by chris williams » 11 Dec 2018, 00:11
Can you post a pic of the part that doesn't fit next to the place it's supposed to fit?
