Page 6 of 9
Re: M100S
Posted: 21 Jan 2019, 10:51
Not ready to talk about that yet Brian................
The second photo does show the gap to have closed a little on full up but that is only because the end is unsupported with the tip block removed.
Re: M100S
Posted: 21 Jan 2019, 21:04
by Jolly Roger
Suffering aileron-envy here.
Often known to hinge my ailerons using the "Diamond tape" method. Highly technical. ;)
Mesmerising workmanship as ever Robbie.
Re: M100S
Posted: 21 Jan 2019, 22:04
Thanks for comment Rog.
Don't worry about the 'Diamond' tape, after the last few weeks it has taken on a whole new appeal for me. I'm a fan anyway, used it lots over the years when its been possible.
Had a sport aerobatic model pile into the slope at a trillion mph some years ago - amongst the sea of 'confetti' there were the ailerons still stuck to the top balsa sheeting/glass cloth with 'Diamond' tape. Be very sad when my last roll runs out.
Re: M100S
Posted: 08 Apr 2019, 21:15
Whoops time - really must concentrate more.
Spot the deliberate mistake:
...........and an object lesson in being careful with the scalpel when trimming Diatex:
Sod stripping it all off, I'm just going to patch the bay and hide the joint when I paint - it's underneath anyway.
Well that's two, just waiting for number three to come along now. This is doing my legendary, speed of light building no end of good......................
Re: M100S
Posted: 08 Apr 2019, 23:40
.........but it would take a lot of the pain away Cliff.
Been sorely tempted to put the whole b****y thing through the shredder before now.
Re: M100S
Posted: 10 Apr 2019, 13:05
by Philkiteflyer
RobbieB wrote: 08 Apr 2019, 21:15 Spot the deliberate mistake:
Uuummmmmm . . .. You used 'Left twisted' servo wire in the right wing ? ? ? :? :? :roll: :roll: :D
BTW, I bet there isn't a fullsize M100 out there that doesn't have any patches . . . a flying one that is. 8-)
You won't see it at 500ft anyway. (the patch I mean :lol: :lol: :lol:
Phillip C
PS:- Do you have a colour scheme picked out yet? I like this one.
https://m100s.jimdo.com/friend-gliders-picture-gallery/
Re: M100S
Posted: 10 Apr 2019, 23:51
Left hand threaded servo cable - how did I miss that :lol:
I think it will be this one Phil:
m100_2.pdf
(213.28 KiB) Downloaded 261 times
Re: M100S
Posted: 18 Apr 2019, 12:23
by Philkiteflyer
RobbieB wrote: 10 Apr 2019, 23:51
That'll do nicely. That yellow should be easy to spot in a blue sky.
Phillip C
Re: M100S
Posted: 27 Apr 2019, 00:11
Started giving some thought to the canopy plug - being rather complicated by the rise at the front of the opening. Not quite as straight forward as a conventional cockpit.
It will be out of high density blue foam so I thought I would produce a plug to exactly fit the opening then add the front, rear and bottom extensions to enable the pull, gradually flattening out the rise to a straight base - unless someone can think of a better way.
Re: M100S
Posted: 30 Apr 2019, 09:30
by VinceC
Stop what you are doing. There is a full size available free and not far away from you Rob
