Jilles Smits 1/3 scale SG38
StephenB
Post by StephenB » 30 Apr 2019, 17:11
Beautifully done Peter, great attention to detail!
I'm guessing that your heart may be fluttering a little on the maiden ..........
Post by Cliff Evans » 30 Apr 2019, 17:17
Peters will not be but mine might be!!!
john greenfield
Post by john greenfield » 01 May 2019, 08:13
Cliff Evans wrote:
30 Apr 2019, 17:17
I am always available to help.
Post by Cliff Evans » 01 May 2019, 09:06
Thanks John but, it is a burden I must put up with!!
Post by Peter Balcombe » 09 May 2019, 18:40
An initial balance indicated that I needed to put around 1.5Kg up front to a achieve the recommended CoG position (151mm from wing LE).
As the internal ballast box will only take 500g, the rest is located in 4 cylinders mounted on additional brackets in a manner very similar to that used on the full size.
The photo below shows the arrangement mock-up.
The rear brackets are bolted to each other through the fuselage, whilst the front brackets have since been silver soldered to the nose bracket and will also have a bolt through the fuselage in addition to 4 of the original 6 servo screws.
The bracketry & weights are currently in the paint shop.
Ballast bar installation
Post by Peter Balcombe » 12 May 2019, 12:38
External ballast bars painted & fitted with just a couple of spots of paint on the fixings now required.
About ready for what is hopefully the final assembly & balance check before handing over to Cliff for addition of the minimal registration lettering and then the maiden flight ;)
Post by VinceC » 12 May 2019, 13:32
Nice work Peter and a good solution to your CG problem
Post by Peter Balcombe » 12 May 2019, 18:06
Just about done 8-)
Ready for maiden flight
Post by B Sharp » 13 May 2019, 07:47
Although it's not my type of model Peter, I have enjoyed your build. Best of luck with the maiden and I look forward to the pictures.
Post by Cliff Evans » 15 May 2019, 14:00
