Page 2 of 2
Re: filler
Posted: 23 Nov 2018, 22:18
by mick a
thanks catwok will try it this weekend
Re: filler
Posted: 24 Nov 2018, 18:17
by mick a
just a bit of info
i didn’t have cellulose thinners , so tried acrylic thinners and worked a treat
thanks again for the tip
Re: filler
Posted: 17 Dec 2018, 09:19
by Pete Marsden
Try 'Upol-Reface' - a polyester spray filler that can be brushed on. It's basically thinned p38. I find it's good at falling into pin holes whilst also able to coat up to 3mm thick 'wet on wet'. Curing time is dependant on how much activator you use (within reason) but typically 20 minutes at 20'C.
Sands as easily as polyfiller and is semi-structural (i.e. replace gel-coat to give a hard surface finish)
The down side is you can only get it in litre+ cans @ ~£20, but you'll keep it forever!
Re: filler
Posted: 17 Dec 2018, 16:57
The only problem with many 2K materials is that the hardener/activator often has quite a short shelf life!
Re: filler
Posted: 17 Dec 2018, 20:49
Re: filler
Posted: 18 Dec 2018, 11:45
by roo Hawkins
My 2k fillers are never around long to go off
Re: filler
Posted: 18 Dec 2018, 14:40
by terry white
Talk to Simon Warren Smith about big problems with 2k paint activator going off.
