frsky RB-10
Moderator: VinceC
jack
frsky RB-10
Post by jack »
Hi all,just got an rb-10 redundancy bus..nice bit of kit,however,l was not too impressed to find that l will need to solder the leads from my two battery packs on to two VERY small solder pads,easy enough if you are a dab hand with a soldering iron, :shock: :l would have thought Frsky could have fitted a plug on each side to plug into,my soldering is definitely of the agricultural variety,usually carried out with a screaming hot 100 watt iron :oops: oh well,burnt fingers again :?
Re: frsky RB-10
Jack,
I agree with Cliff, especially if all you have is a 100w soldering iron and limited soldering experience.
The contacts are quite small and close together, so easy to bridge the contacts/overheat & take them off altogether - thereby probably destroying the unit.
I would suggest either changing the unit whilst still in perfect condition, or finding someone nearby who can do the soldering for you.
