Paritech Nimbus 4D
Mike Francies
Paritech Nimbus 4D
Post by Mike Francies » 04 Feb 2019, 22:15
Hi,
I am putting together a 7 meter, Paritech Nimbus 4D that I purchased through John McNamara at Soarstream. John has been brilliant as there were one or two issues with the model which he dealt with very expeditiously. I will try to post as many photos and detail as I can but don't expect this to be a quick build, I am the world's slowest builder!!
At my local field, we do not have a suitable tug available so I have opted for a Schambeck AFT19 to haul the beast aloft so I can take full advantage of all possible flying days available to me.
I also bought the cockpit to fit and a Tailored Pilots, quarter scale pilot, which is brilliant. The Nimbus is at 1:3.75 scale so a 1:4 scale pilot should be too small. The pilot measures 375mm which, even at 1:4 scale, makes him a bit small at around five feet! However, putting him in the cockpit means I cannot close the canopy!! What is happening? I am presuming the cockpit has been made shallower to allow gear to be put under it. So how do I get my pilot in?
That is not the only problem with space as I also need to get in all the paraphernalia for the AFT19.
Mike Francies
Re: Paritech Nimbus 4D
Post by Mike Francies » 05 Feb 2019, 11:08
I appreciate there is a little bit of resistance to so called 'cheque book' modelling and, to a large extent, I too am reticent. However, for me, this is a means to an end as I have also embarked on a large, scratch build project and the Nimbus can be construed as research. The scratch build is of similar dimensions and is somewhat larger than my largest thermal soaring models of the 1980s/90s. I will start another thread for the scratch build. My building and flying time is very limited due to domestic issues so I hope there won't be too much critisism :)
Getting back to the Nimbus, I was very surprised to find the wing section was 16% thick throughout the span. This has made me think of the wing section for the scratch build as I was going for somewhere nearer to 11-12%. I have now decided that 14-15% would be okay, besides which, a thicker section also means a deeper spar.
Below is a sneak preview of the scratch build that will use many of the systems I am trying on the Nimbus.
Post by Barry_Cole » 05 Feb 2019, 12:07
That looks great, and Brian will be proud of you.........
8-) 8-) 8-) 8-)
Mike Francies
Post by Mike Francies » 05 Feb 2019, 20:31
This is my take on the problem of wing root servo connectors. The holders for both the pins and the sockets are 3D printed. You can just about make out the labelling for the five servos, positive and negative lines. The insulation and cable retention is done with hot glue gun injected into an aluminium mould. The moulds were cut on my home made CNC milling/router machine.
I am the world's worst solderer and I did not like the idea of soldering up a 9 pin din plug and socket so I made my own from 2mm bullet connectors. These are permanently fixed in the wing roots and make automatic connection when the wings are put together. The advantage of the 2mm bullets is that they have a much longer insertion than the din plugs, some 9mm compared with just 2mm for the dins.
The exposed pins are protected with a 3D printed protector.
Post by Peter Balcombe » 05 Feb 2019, 21:32
Mike,
Some excellent engineering there & a lovely job.
Hopefully the much longer contact length will mean a more reliable connection at all times.
However, if you have ANY movement between wings & fuselage parts (even vibration) your system may still be prone to contact wear & resultant reliability issues over time.
The ideal with any two part connector system is to have one side slightly “floating” so that it can remain perfectly still with respect to the mating contacts.
Good work though.
Mike Francies
Post by Mike Francies » 05 Feb 2019, 22:05
Hi Peter, thanks for the feedback. I will keep an eye on the connectors. The huge, steel joiner is a fantastic fit in its wing tubes and affords virtually no movement whatsoever but your point has been noted, thanks.
John Mcnamara
Post by John Mcnamara » 05 Feb 2019, 22:21
Hi Mike,
If you look at Multiplex connectors or computer "D-Plugs", the pins have a small degree of movement within the insulator block. As a result, I have never had a problem hard mounting either of these systems in wing and fuselage, and getting 100% reliable connectoin.
So my question is, are the pins a tight fit in your insulator blocks or is there some slop? If its the latter, then I doubt you have a problem. If, the pins cannot move, then I would check the connection out by supporting the the finished model at the half span and " bouncing" it on its supports to represent gust loading, as well as carefully checking smooth servo movement at the same time.
Subscribed BTW.
John
Mike Francies
Post by Mike Francies » 05 Feb 2019, 23:00
Hi John, the pins themselves have the spring loaded contacts on them so there is some allowable movement within the socket whilst retaining electrical contact. I am pretty confident they will do the job. The outer wing panels have the six pin Multiplex plugs and sockets mounted in a similar fashion, but I needed a minimum of seven pins for the root connection.
Getting there slowly!
Jolly Roger
Post by Jolly Roger » 05 Feb 2019, 23:25
That fuselage plug looks quality Mike! Lovely work.
Hmmmm. Long shot this, but there was a nice thermal soaring design in the 1990s called the Optimist - was that yours? Your name rings a bell. ;)
Mike Francies
Post by Mike Francies » 06 Feb 2019, 08:40
Hi Roger, guilty as charged! :lol:
