Bridson Jig
MikeA
Bridson Jig
Post by MikeA »
Chaps, any photos (or manufacturing info) of the eponymous wonder-jig? I feel a fuselage coming on :o
Cheers, Mike
StephenB
Re: Bridson Jig
Post by StephenB »
I've just recently made one, 35mm x 35mm ali angle, right angle brackets from builders merchants along with wingnuts and bolts:
MikeA
Re: Bridson Jig
Post by MikeA »
Excellent! Many thanks Steven.
Re: Bridson Jig
Mike, if you can't get the mounting brackets you can always buy longer lengths of the base angle that is required and cut pieces off for the brackets which is what I did with the original. Downside is, they will have to be drilled for the securing bolts.
