Paint finishes for Diatex
Malcolm B
Post by Malcolm B »
Morning all!
I am probably being dense or accused of "man-looking" but searching high and low I cannot find the thread on the hot favourite paint types for Diatex. My current thinking is to use acrylic over the initial dope sealer coat. Ideas please!
Geoff Pearce
Re: Paint finishes for Diatex
Post by Geoff Pearce »
I'm going to use two pack on my ORLIC , red and white
mick a
Post by mick a »
hi
i spoke to someone who has used diatex for a few years and they use normal car paint or enamel ,or even humbrol without primer etc, and seem to get good results
john greenfield
Post by john greenfield »
I have been using Diatex to cover my models for years and highly recommend that you use coloured dope. Using dope will ensure a good bond to the clear dope you used to seal the weave and it will remain flexible so there is no chance of the paint cracking as the fabric moves under air and handling loads.
I get my coloured dope from Skycraft Ltd, the same place that sells the Diatex.
Malcolm B
Post by Malcolm B »
Thanks all
John do you know if the cellulose car paint is compatible with the dope which I believe is also cellulose based?
The choice of colour is better with cellulose paint.
Malcolm,
Diatex takes car acetone based cellulose very well on top of dope filled weave. Just control the amount of fill you apply for the desired finish.
john greenfield
Malcolm
Cellulose car paint is not flexible so will crack over time as the fabric moves unless you add a plasticiser to the paint. Personally, I have not had much success with additions which is why I now use dope. Skycraft Ltd can mix dope to any colour if you have the BS or RAL number.
Malcolm B
Post by Malcolm B »
Excellent
If they can mix to a RAL code then that is the job sorted
Thanks!
Except that they currently appear to be out of stock of both the lightweight Diatex & most of the coloured dope products!! :o
.................and I need some of that!
