Anyone wishing to register, once you have, PLEASE CHECK YOUR SPAM FOLDER for the confirmation email. {And please, if possible can you use your real names! there are far too many numbers and silly titles being used}
canopy frames
mick a
canopy frames
Post by mick a » 13 Mar 2019, 07:22
hi gents
has anyone got a method for making canopy frames ?
it’s just trying to get correct curve etc
Re: canopy frames
Post by chris williams » 13 Mar 2019, 09:49
The easiest way to obtain a curve in a canopy rail is laminate, say, two strips of 3 x 6mm spruce together, and fix them to the curved part you want to emulate, packing out slightly to allow for the inevitable spring-back when the epoxy has cured.
Canopy frames can be either cut directly from 3mm ply or similar, or laminate with strips of 0.8mm ply wrapped around a correctly shaped former...
mick a
Re: canopy frames
Post by mick a » 13 Mar 2019, 18:48
thanks chris
as always , fountain of knowledge
