Minimoa colour scheme
Hello all,
I found this old B&W photo of a Minimoa on the Schempp Hirth website. I am having problems deciphering what the colour scheme is on it and I would appreciate your opinions as I'm not finding anything else on the internet.
Thanks in advance,
Ian
Thanks in advance,
Ian
Re: Minimoa colour scheme
Ian,
The name on the side suggests Cheminitz which is a city in the Dresden/Saxony area of Germany. The colour schemes of German sailplanes from this era were usually region dependent and if this one follows that convention then it would be white and green for Dresden.
The band on the fin and rudder frequently indicates an attempt to obliterate the swastika that would have been painted there, quite often done later in the printing/publication stage and might be in the original red or even black.
I'm sure Vince will be along soon with a much more accurate and in depth explanation.
Thanks Robbie, Do you know if the green is an RLM colour? I'm assuming the tail number 23 has to be white since its so highly constrasted and the rest of the airframe would be ivory & doped linen?
Cheers,
Ian
Cheers,
Ian
Would the front of the fuselage be white too? seems to be a highly contrasted colour also.
Ian
Ian
- VinceC
- Site Admin
There is no white on the glider, except the competition number. See this page from the original site for the colour of the D-7-.... region
Whatever the colours, the front of the fuselage is significantly lighter than the rear.
Perhaps this might clarify it a little better:
...............and from a VGC article by Chris Wills from the 1980's:
Thanks for sharing the articles. That really clarifies things. Should be a very attractive and interesting scheme. I am assuming it would be RLM 25 Bright Green which seems close to grass green. With all the different colour combinations, there should be enough choices to keep everyone happy. Now to find an interesting scheme for a Kranich!!
Thanks again to all
