SG38 1/4 Scale (Krick)
OK so I finally found my way back to the building board to build my long awaited 1/4 scale SG38 which I purchased several years ago.
Re: SG38 1/4 Scale (Krick)
All of the instructions for the kit are in German, fortunately when I purchased the kit a few years agao I had the foresight to source a translated version.
So if anyone else is thinking of building one of these you'll more than likely need these translated instructions which can be found here:https://drive.google.com/open?id=1BQrlf ... HzajEO6D0O
Hope this helps.
Hope this helps.
OK so lets start with the fuselage:
Some of the hardware:
Fuselage and "A" frame assembly:
Wing centre section:
Nice! Quick build!
LOL
Yes I don't hang about, should be done by lunch time
Skid Lamination & Shock Absorbers:
make up lamination spacers and angle pads for Ply, trace out from plan, make template, soak in hot water, glue bend slowly while attaching clamps, leave to dry:
