Jim Andrews
Just joined the forum? Please introduce yourself here..
Jim Andrews
Jim Andrews
Post by Jim Andrews »
Hi I must be the newest member! I have been building and flying model aeroplanes (mainly gliders) for 80 years. At present I am building a "Jaskolka
I started it quite a long time ago but this time I am determined to finish it, wings to go but all ribs cut. Next probably a Cliff Charlesworth design as I have the plans and canopy for the reiher and the ASK 13.
I should have said I am a member of the White Sheet Club but it is quite a distance from South Wales!!
Enough for now
Jim Andrews
Jim Andrews
Re: Jim Andrews
Thanks Cliff. I was thinking of contacting you as I have some queries. Is it no longer possible to obtain spring steel and brass box wing joiners? My jaskolka has built in tubes in the fuselage but obtaining 14 x 2 mm steel seems impossible . Any ideas please?
Jim
Re: Jim Andrews
Yep, 14x2 steel steel strip & box has been superseded by 15x2 as sold by Gliders Distribution.
I have used in in a number of builds over the past few years :)
