Hi Paul,
Don't even think about it, Sorry. Terry
Wing joiner blades
- terry white
- larrikin
Re: Wing joiner blades
Gents,
Probably a long shot but is there ANY manufacturer that produces spring steel blade joiners these days?
I'm restoring an 25% K-13, built from Charlesworth plans by my father over 30 years ago.
He decided in his naivety to set 5/8 i/d aluminium tubes between, and parallel to, the spar caps instead of perpendicular to the fuselage.
This brought about some "issuses" regarding the bend in the aluminium rod that he used as the joiner bar.
Any "G" loads (+ve or -ve) tried to rotate wing and put unneccessary loads on the fuselage.
I've removed the lower sheeting around the aluminium tubes and ground them out, leaving the spars intact.
Ideally I'd like to build it as per plan but if I can't get the spring steel blade then I'll need to return to tubes and rod.
Thanks
David
Thanks
David
Avatar is K7 VH-GQX in 1980.
David,
You can get the traditional flat steel joiners from Gliders: http://www.gliders.uk.com/Steel-wirerod ... oducts/58/.
You can get it from other sources but Gliders usually give very good service. If you do source elsewhere I would recommend the 15mm in preference to 14 as it is often a better fit in the brass tube.
New alarm clock for Christmas is it Barry?
Hi Steve,
If you mean 15 x 2mm steel blade with a 3mm brass box, Gliders are the best bet as per Robbie's thread. Hope this is what you intended, if not perhaps someone else might know where to get a 3mm steel blade !!
Geoff
Geoff
aka Motley
- larrikin
Careful what you order, Steve: I have noticed that they show the blade in two thicknesses, 1.5 and 2mm
