ZUGVOGEL IIIa 1/4.2 SCALE
Re: ZUGVOGEL IIIa 1/4.2 SCALE
With the rudder made up and hinged to the fin, the whole assembly can be glued to the fuselage, thus completing this part of the process...
Next he will be telling us he has run out of servos. Who would do that??
Just had a visit from the Servo Fairy...
I know he's a bit short, but that's going a bit far....
Mmmm, obviously going to have to change those shorts Still, on another note, i wonder if i'll find a couple of quid under my pillow tomorrow morning ????
Geoff
Geoff
aka Motley
Moving on now to the wings...pretty conventional stuff: single 15mm wing joiner, and the aileron spar is located by the ends of the sub-ribs...
The ribs are 2.4mm balsa and the main spar 5mm sq spruce.
That's better, well done Cliff...Time for a dihedral check before committing epoxy...
You are welcome!
