Cranked prop hub supplier?
Does anyone know where you can get these from? The offset enables the blade to sits much closer to the fuselage when not in use. I know the F5J folks use them but I need one to take a larger motor shaft of 8mm.
Thanks,
Re: Cranked prop hub supplier?
Hi Rog. Try Hyperflight.
Thanks Brian yes they were my first thought...but sadly they have none for 8mm shafts.
Phill Tadman
Post by Phill Tadman »
Hacker have these in various sizes
https://www.hacker-motor-shop.com/Acces ... 200&p=4737
Phill
Phil - this looks PERFECT! I am so grateful. Will order a couple tomorrow.
Thanks again.
