Re: Servo voltage regulator
Posted: 10 Jun 2020, 22:23
Frank,
Another possibility is a buck converter module like this one which can convert a supply from 6v or so down to a lower voltage at up to 3A.
https://www.ebay.co.uk/i/254490668546?c ... gJdGPD_BwE
if you have more than one low voltage servo, then they could all be run from the same 5v supply, with commoned 0v & the servo signals from the high voltage Rx via protection voltage dividers or limiters.
