R8xr binding problem
Posted: 27 Jun 2020, 18:32
by roo Hawkins
I have just taken a rx8r rx out of a model to move in to adifferent model. It was working OK but when I tried to rebind it in none telem mode I am only getting a none flashing red light. Anyone have a idea thanks Roo
Re: R8xr binding problem
Posted: 27 Jun 2020, 20:50
Roo,
Have you got the Tx too close to the Rx whilst binding?, try putting >1m from the Rx.
Have you jumpered the right pair of RX channel signal pins depending on whether you want channels 1-8 or 9-16 for non-telemetry mode.
Presumably Tx is set up for D16 operation.
Posted: 27 Jun 2020, 22:13
by roo Hawkins
Hi Peter. I have been and looked again and no luck. More than 1 meter apart and try with and without jumpers. Roo
Posted: 27 Jun 2020, 22:57
by MDev
Battery connected correctly, have you connected to the wrong terminals?
Wrong voltage?
Is the jumper on the control pins?
What tx module do you have? Are the switches set to down on the transmitter rear? Check 2.4ghz transmission. Is aerial secure?
Been there done that! Got the t shirt as well......
Posted: 27 Jun 2020, 23:04
If all else fails, see if you can rebind it in the original model configuration with original Tx model memory if that is still possible.
If the Rx came out of a damaged model then the Rx may be damaged.
Posted: 27 Jun 2020, 23:37
by roo Hawkins
Yeah I have tried to rebind bind to the original model.it is not a old rx and as never been crashed. Just taken it out of one model put it another and when I went to bind it's only red. .
Posted: 28 Jun 2020, 08:54
Posted: 28 Jun 2020, 09:02
Roo,
Ok then it’s likely to be something simple - but what
I would go back to basics, checking that the Tx can bind to another Rx, then tried RX8R setup from scratch out of a model - just Rx & battery.
I can’t see a Red LeD ON state in the RX8R instructions, so not sure if this is a valid state or not.
Presumably you have to set your Tx module to bind using a F/S button. Instructions mention a Red Led during binding procedure, but I think they are referring to one on the Tx, not Rx.
Posted: 28 Jun 2020, 10:44
Have you updated anything lately?
Posted: 28 Jun 2020, 11:48
by Martin Gough
Have you set your radio correctly? On page 2 make sure Mode is set to D16 and when you press bind
select Ch1-8 Telem on. Set the rx first to bind ie power on with button pressed. Should get red light.
When you set tx to bind after a few seconds you should get green. Un plug and take tx out of bind.
You probably know all this but I bound one yesterday ok using the method.
Posted: 28 Jun 2020, 12:43
I have just had a long chat with Roo, and we feel that the Rx has died. He is going to get a new one, and see how that goes.
Posted: 28 Jun 2020, 13:50
by StephenB
That's unlucky, FrSky stuff is normally super reliable I believe.
Posted: 28 Jun 2020, 14:08
by roo Hawkins
Thanks all for the advice and help. I have tried all the above. Could spend hours at it but life is to short to be bothered with a £35 rx.
