That can really only be your decision, It is what I would do!mjcp wrote: ↑01 Sep 2020, 09:10 Intriguing! Yes please, would be good to confirm and set the correct CG!
Any other identifiers you can think of?
... and the follow on question:
Do I leave it "as-is" for "historical accuracy" or fit servos in the wings to make rigging a straightforward process (currently there are 4 ball joints to pop on/off in addition to lining up they forks) as a winter project?
Marc
PT ASW20 & Pik20 CG suggestions please
Re: PT ASW20 & Pik20 CG suggestions please
MJCP, Regarding the CG position I think Pat went for an ultra safe setup on his instructions. Having owned most of his range over the years (inc 3 Pics and 3 ASW20s) and flown many more they all were a bit puddingy with the recomended CG position. OK perhaps for the slope but disappointing when flown on the flat. After trimming mine I usually ended up with the CG between 10 & 15mm rearward.
My advice would be to balance initially 10/15mm back from the recommended position then add a few removable blocks of lead to bring the CG back to its recommended point before first flight. You then have the option of removing little chunks of weight to trim the model to your personal flying tastes.
Marc,
Check out my recent PIK20 rebuild thread in the rebuilds section.
I did major repairs on the rear fuselage/fin & then used a new built-up wing structure which has 3 servos in each wing.
It may be worth thinking of modifying your foam wings at some point to fit flap servos in a balsa lined box after cutting an appropriate recess in the bottom of the wing. You can probably use a sharpened rod pushed through the foam to arrange your servo wire to exit next to the others to make rigging easier. (I have a single 6 pin MPX connector for all servo connections.)
I’ve initially set the CoG as per the plan figure, but as Brian says, Pat always identified a very safe position to start with, allowing the pilot to trim backwards to taste.
- Max Wright
I'm doing exactly that on my Caproni Calif A-14.
I'll post some pictures of the modification to the spoilers this week.
viewtopic.php?f=57&p=28511#p28511
Max
- mjcp
Both were re-maidened this past weekend on the Bwlch / Mickey's. Winds were fresh at 20mph on the edge for the PIk20 and ~15 for the ASW20 the following day.
Video Linky - iCloud share
Classic post maiden photo-ops:
PIK 20 post re-maiden
ASW 20 post re-maiden
m̶j̶c̶p̶ Marc
Hanger -
Hanger -
