Balsa
Balsa
SlecUK are more or less out of Balsa!
- BrianF
Re: Balsa
Hopefully its just a temporary supply glitch due Covid. Just as building your own models appears to be growing, the raw materials run out.
So far so good in this part of the world, balsa is expensive, but is available. I just ordered some to cover my upcoming builds in case.
Spruce is crazy expensive here, if you can even find it. Luckily some local timbers are a reasonable substitute, but you have to cut your own to get the size you need.
So what alternatives?
Balsa ribs can be substituted with ply with larger lightening holes per many ARF kits. Easy to cut on a laser cutter, more challenging to cut manually. 3D printing, foam and glass can replace some of the parts we used to carve from blocks like noses and wing tips. I was given a big box of odd sized balsa blocks years ago that will see me out. Sheeting is the tough one. I have thought about slicing thin sheets from blue foam on my foam cutter and glassing that after install. Would need to adjust plans to cope with a thickness of say, 5mm?
Modellers are an adaptive lot, what else might be used?
www.seqsa.net
www.seqsa.net
Re: Balsa
According to Slec, there will be nothing here until Feb and even then the price may have trebled! I am quite happy to cut parts normally cut from balsa sheet from poplar ply as it is very light and just as good to use and available in the same thicknesses. However, from experience, modellers will want what is stated on the plan!
- BrianF
Re: Balsa
What about putting a disclaimer on your orders stating that balsa will be substituted for ply where possible, I know some people will still complain but if the choice is a kit with ply or no kit I suspect even the diehards will accept it. If the Chinese are buying all the balsa for wind turbine blades then this isnt going to be a short term thing. I read the other day that old turbine blades is the USA are being buried in landfill as they cannot be recycled. I am assuming the design of these doesnt use balsa as surely that could be reclaimed?Cliff Evans wrote: ↑30 Oct 2020, 22:30 According to Slec, there will be nothing here until Feb and even then the price may have trebled! I am quite happy to cut parts normally cut from balsa sheet from poplar ply as it is very light and just as good to use and available in the same thicknesses. However, from experience, modellers will want what is stated on the plan!
Re: Balsa
Yes Pat, have done that on my website already.
Re: Balsa
Re: Balsa
You would have thought that with modern technology and materials you wouldnt need to use balsa wood in wind turbine blades
