Page 4 of 8
Re: MINIMOA 1/4 SCALE
Posted: 06 Dec 2020, 08:32
The wing joiner box is set behind the main bulkhead, and packed out at the top to align with the angle of the wings...
Posted: 07 Dec 2020, 05:47
by Paul Neville
Hi Chris, is this new plan available to purchase yet?
Posted: 07 Dec 2020, 08:23
It's being donated to the forum, Paul: you can get a copy plus the parts PDF's from me...
c_williams30@sky.com
Posted: 07 Dec 2020, 10:09
The crescent shaped ply part on the rear cockpit bulkhead performs the twin duties of tying the two former halves together, and providing an edge to which the canopy can be glued.
The canopy frame is built up in place, with the starboard rail first being hinged up with brass doll's house hinges
Posted: 08 Dec 2020, 12:24
When adding the ply sheeting, I always find it easy to apply it in two halves, with the join in the middle, over the short longeron...
Where possible, the joints are reinforced with short lengths of fine piano wire, inserted via the drill...
Posted: 10 Dec 2020, 08:08
The aileron shrouds are made up from 0.6mm ply, grain cross-wise, and 1.5mm balsa sheet. The balsa will be later sanded flush to the cap strips
Posted: 11 Dec 2020, 08:17
The ailerons are built flat to the board...
Posted: 12 Dec 2020, 10:01
The ailerons are hinged with Robart style hinges. The final LE is rounded off in order for it to rotate within the aileron shrouds on the wing. The hinges are supported in the wing with 9mm dowel, and the hinge knuckle set back in the aileron to allow for correct rotation. The servo is mounted on 3 x 6mm spruce rails...
Posted: 13 Dec 2020, 08:24
With the fuselage now fully sheeted, it's time for the tricky business of setting up the wings in their rightful place...
Posted: 14 Dec 2020, 08:00
The 1.5mm ply wing fairing plates are set up flush to the wing, and the space in between filled with balsa, then finished with polyester filler...
