control surface shrouds
I am thinking about building another motor glider and unsure how to provide a shroud at the control surfaces , to maintain the airflow
If any members could provide any advice I would be most grateful,hopefully looking for something not too difficult or time consuming if thats possible ?
Thanks Ian Turney-White
Re: control surface shrouds
Hi Ian
What sort of hinging are you proposing, top, center, or bottom hinged? I make my shrouds from thin ply.
John , thanks for your reply , thinking of top hinges , works well with lower horn, regards Ian T-W
- terry white
Hi Ian, give Stan Yeo a ring at Phoenix Models in Newton Abbott or look in on his Webb site. He sells a number of ABS sheets with the shrouds already vacformed within. Not expensive and very quick to cut out and use.
Phoenix Model Products
Model shop in Newton Abbot, England
Address: 3, Salisbury House, Salisbury Road, Newton Abbot TQ12 2DF
Hours:
Closed ⋅ Opens 10AM Fri
Phone: 01626 332287
Hours:
Phone: 01626 332287
- Max Wright
Hi Terry
That sounds great. I've spent a little time on his site, but I can't find it.
The Search box comes up empty.
Max
Max,
They seem to be in the servos section as ‘servo covers’
- terry white
Peter's correct under servo covers it is. He also sells in-wing timber servo mounts, He's a nice guy been at it years (could be my dad) Tell him I sent you, he'll charge you double.
- Max Wright
Hi Guys
I think from Ian's original post that he is looking for shrouds for the control surface gap to maintain the airflow and not covers for the servos.
Ian
Depending on the gap that you want to cover I would suggest Mylar strip. For smaller gaps, this could be drafting film or for larger gaps, you can buy thicker mylar for the purpose direct from Topmodel.CZ and I am sure other places. The mylar from Topmodel comes with a double sided tape on one side for sticking it to the model.
Ian
Thanks gents , Johns idea of mylar with an adhesive strip looks promising , but unable to find it on the topmodel website
