ASK13 1/3 Scale**
Re: ASK13 1/3 Scale
john greenfield wrote: 07 May 2021, 08:14 I actually use "Balsaloc" to attach the covering as you can just iron the covering on with a low temp iron (not hot enough to shrink the covering but enough to activate the Balsaloc). Once attached I brush dope around the edges and any undercamber to lock the covering to the structure and then start the shrinking process with a hotter iron.
How do you get to the under camber, after you have sealed the edges??
Re: ASK13 1/3 Scale
Barry_Cole wrote: 07 May 2021, 20:06
Just leave the covering slack enough to be able to get it to reach the under cambered ribs Barry, then shrink to tighten once secured. :roll:
Re: ASK13 1/3 Scale
Prototype 3D printed seat checked for size.
Improved ones with full scale cutouts to be fitted in due course.
john greenfield
Re: ASK13 1/3 Scale
Post by john greenfield »
I attach to the root and tip first and then starting at mid chord work forwards and backwards attaching it to the undercamber before securing it to the leading and trailing edges !!
Re: ASK13 1/3 Scale
Paint job coming on!
Re: ASK13 1/3 Scale
Paint job done just decals to add.
StephenB
Re: ASK13 1/3 Scale
Post by StephenB »
What a striking model, beautiful job as ever Peter.
Re: ASK13 1/3 Scale
Paint job isn’t mine , but nice work anyway :)
Should look even better once the decals are on.
Re: ASK13 1/3 Scale
Finished!
catwok
Re: ASK13 1/3 Scale
Post by catwok »
Beautiful looking model Cliff, mine will only come out after sun set now!
