Page 1 of 2
Looking for something different to build?
Posted: 10 Mar 2021, 19:44
Re: Looking for something different to build?
Posted: 10 Mar 2021, 22:04
by Dave Mackintosh
Foam and carbon? Cliff.
Posted: 11 Mar 2021, 00:11
by Jilles
an early attempt to wing lets as well
Posted: 11 Mar 2021, 09:20
by john greenfield
Interesting "fins" on the wing tips. I can't help but think all they would have done is create drag and turbulence !!?
Posted: 11 Mar 2021, 13:36
by MDev
An obvious attempt at a sail plane! Can it be reefed?
Posted: 11 Mar 2021, 13:57
by mjcp
I guess I will never know...
Posted: 11 Mar 2021, 14:40
mjcp wrote: ↑11 Mar 2021, 13:57
Have you got an add blocker enabled?
Posted: 11 Mar 2021, 16:23
Marc,
It's also very likely your script blocker is stopping it (if you have one active). You will have to allow Facebook to run scripts on the page.
I have a very effective ad blocker and I don't need to turn it off to see the post.
Posted: 12 Mar 2021, 10:34
by mjcp
RobbieB wrote: ↑11 Mar 2021, 16:23
Might I suggest its not quite as effective as you might think, if you can see the content, then FB et al are tracking you, therefore you are not actually blocking the ads, just the presentation of (some) of them.
As for my own infra, I use a PiHole to block ads
and tracking at the router/DNS level. I see the same result on both work's laptop and my own iPad.
Posted: 12 Mar 2021, 10:49
by Philkiteflyer
I use Firefox browser and got the same message. So I tried using Chrome and I got it to work.
The obvoius pun is " an early sail plane" Sorry.
Worth a try
Phillip C
