DIY CoG Meter
Posted: 11 Mar 2021, 11:38
Following on from interest expressed in the Albion build thread, I've started this thread to provide more details of my DIY Centre of Gravity measurement device.
This device is similar to commercial items available from Hyperflight etc. but these commercial units seem to be aimed at the smaller & 'flying broomstick' type models as Pat Teakle would call them. (A Hyperflight unit currently costs approx. £115 & can handle narrowish fuselage models weighing up to about 4Kg).
T9HobbySport also do 2 very similar looking units for £103, capable of 4Kg & 8Kg. They are apparently designed for F3x models & are limited to a maximum fuselage size of 52mm.
I wanted to make a device which could handle 1/4 scale sailplanes weighing up to 5Kg or more.
So .....
The device uses 2 beam type load cells to measure the model weight as sensed at 2 positions across the wing chord, then calculates the overall model weight and the point between the two measurement points that this weight acts. By positioning the weighing points at a known separation & distance from a wing LE reference, the CoG position can then easily be displayed with respect to the LE.
There are various articles & uTube videos on the web relating to weight measurement with Load Cells using the HX711 amplifier and Arduino processor units, plus an article I found on Soaring Planet describing how to calculate the CoG from 2 weights.
The pictures below show my bare device, plus a schematic of the electronics used to measure the weights display the overall model weight plus CoG position behind the LE.
The 2 weight sensors are simple beam load cells which each contain 2 strain gauges mounted across the thinned part of the beam. The strain gauge resistors are internally connected as a Wheatstone bridge arrangement, which when connected to a HX711 amplifier module, produce digital data which can easily be processed by an Arduino processor.
I use the Arduino Mini Pro, but the Arduino Nano would probably be slightly easier to use in hindsight as it has a built-in USB computer interface.
The serial connection (I2C) 16x2 LCD display module gives a readout of overall model weight & current CoG location after a short initialisation process.
The load cells are available with different measurement ranges (e.g. 3Kg, 5Kg, 10Kg etc.), so it is possible to select units which best cover the range needed for your purposes. The load cells need to be used initially with a calibration program running the Arduino & known weights placed on each sensor separately in order to get a calibration value to provide accurate measurement values.
Use of the Arduino processor modules is fairly easy, but means using the Arduino IDE application on a PC/Mac to be able to upload the firmware code to the device.
The overall unit is fairly cheap to produce as the load cells are available for £7.50 each, the HX711 modules for £2.50 each (from China), the Arduino for £4, and an I2C display for <£5 (from China).
Re: DIY CoG Meter
Posted: 11 Mar 2021, 11:54
On the software front,
I have attached a number of zipped files which contain the firmware program ('Sketch' in Arduino IDE terminology), plus a calibration program and the 2 libraries (HX711 module & LCD module) needed to compile the program.
I also include an I2C scanner sketch which enables you to identify if the display is properly connected and what its communication address is, as this may be different from the one applicable to my display module.
If anyone interested in building the device is not 'au fait' with the Arduino IDE, then I can provide more detailed instructions.
Note that the HX711 library examples includes a calibration sketch & examples suitable for single load cell measurement.
Re: DIY CoG Meter
Posted: 11 Mar 2021, 12:55
by mjcp
Do you have to shuffle the airframe fwd and back? Or do you place it at a known distance from the leading edge and allow maths to work it out based on the pair of load cells?
Assume it is only valid for straight / traditional wings?
Marc
Re: DIY CoG Meter
Posted: 11 Mar 2021, 13:23
Marc,
On the pic of the overall unit, you will see two vertical pins forward of the front rest pads.
The model is sat on the unit with its LE up against those pins, thus putting the measurement points a known distance behind the LE at this point.
(The distance between measurement points and the reference point are all adjustable in the firmware sketch prior to compiling the code.)
Thereafter, the model stays in the same place as you adjust ballast to get the CoG where you want it behind the LE at the pin spacing.
For a swept LE, unless it’s a very sharply swept wing then it probably won’t make too much difference, but you could either make the spanwise pin width adjustable (which may lead to location errors), or just adjust the required CoG distance to account for the spanwise difference in root LE & measurement LE point for a particular model.
(I’m not sure if commercial units are adjustable anyway).
Re: DIY CoG Meter
Posted: 12 Mar 2021, 13:10
by mjcp
Ah, so this helps to ballast --> to a correct CoG, without the need to add/recheck / adjust by hand?
Think that makes sense.
Marc
Re: DIY CoG Meter
Posted: 12 Mar 2021, 13:52
Yes Marc, once it’s on the stand you can leave it there & just adjust ballast until the CoG position is where you want it.
Gives you overall model weight as a bonus
Re: DIY CoG Meter
Posted: 21 Mar 2021, 18:57
I’m also looking at a 4 load cell version for heavier/larger models.
This version replaces the 2 ‘U’ frames/3D printed units in commercial versions (which constrain the fuselage width & depth capacity) with separate left & right assemblies which can either be fixed at a suitable separation, or slid apart on 3 rods.
The front & rear pairs of load cells generate the equivalent 2 weights as for the 2 load cell version.
The idea is that with two sets of 4 different 3D printed parts and a few 6mm carbon/metal rods, the support/weighing setup can easily be adjusted to cope with different model sizes & weights. The electronics just needs 2 extra HX711 amplifier modules & a different firmware program loaded in the Arduino.
The load cells can easily be uprated to higher load versions.
I’ve just received 2 extra sets of 10Kg load cell + HX711 amplifier. These only cost me £7.54 in total & arrived within 10 days
Re: DIY CoG Meter
Posted: 01 Apr 2021, 16:40
by Robcrad
Hi Peter,
I am going to have a go building this system, had enough of trying to balance a glider on my finger tips. i am a complete beginner with Arduino and you mentioned you had some more detailed instruction, would it be possible to get a copy of these please?
Many thanks
Rob
Re: DIY CoG Meter
Posted: 01 Apr 2021, 18:20
Hi Rob,
The first thing is to download & install the Arduino IDE onto your PC (There are also Mac & Linux versions but I have only used the PC version, so any instructions will only be for that).
Latest version of the IDE appears 1.8.13 & is available from
https://www.arduino.cc/en/software.
Once you have the IDE installed & have an Arduino Nano (onboard USB interface makes it much easier to program & debug), plus the load cells, HX711 amplifiers & an I2C 16x2 LCD display connected up as per my schematic diagram then we can set about getting the firmware loaded.
I’m assuming you are ok with following the schematic & soldering things up, plus making up the two model rest arrangements to support the model via the two load cells.
The details of the mechanics are up to you, depending on the type & size of models you want to cater for.
It may be worth initially just making a simple bed to fix the load cells down a known distance apart to check everything out - and then make up your mechanics later.
Rather than clog up the forum thread, it may be better if you send me a PM with your email address so that I can get you going.
The first steps will be to making sure you can get the IDE to recognise the Arduino unit when connected via a suitable USB cable. Once you can successfully do that, we can compile & upload a test program.
Re: DIY CoG Meter
Posted: 01 Apr 2021, 20:32
For anyone that has downloaded the HX711_ADC library from an earlier post, please note that I have just replaced this library with an improved version.
If you have already installed the previous HX711 library into your IDE libraries folder, please delete the previous library folder & replace with the new one. Note that when you extract the library folder, change the name to just "HX711_ADC" - i.e delete the "-Master" bit.
The huge advantage of the new library is that the calibration sketch contained within the examples folder is much easier to use, so use this instead of the previous one. You just place a known weight on the load cell & enter the weight via the serial terminal (& press the Return key). The sketch automatically calculates the precise load cell calibration factor rather than having to manually adjust.
I am currently working on an improved version of the 2 load cell CoG meter which includes the auto calibration feature.
Re: DIY CoG Meter
Posted: 02 Apr 2021, 09:06
For those of you using a USB device which has a CH340 USB/serial interface onboard (such as some of the Arduino Nano units), you may need to install a CH340 device driver in order for it to be recognised by the PC.
Sparkfun have a helpful web page for this which includes a link to the driver
https://learn.sparkfun.com/tutorials/h ... rivers/all
If the correct driver is installed, the device will show as a new USB port on the PC system info. page & as a Serial Port in the Arduino IDE.
Note that an Arduino Nano uses a USB Mini-B connector, so you need the appropriate USB cable to connect it to your PC.
Re: DIY CoG Meter
Posted: 03 Apr 2021, 13:04
I have managed to produce what is hopefully an improved version of the 2 loadcell CoG meter firmware as attached.
This version uses the onboard EEPROM to save calibration values determined during a calibration process which runs automatically upon 1st use & can also be run at any time afterwards if the unit is connected to a PC & using the Arduino Serial interface.
The calibration process calibrates each sensor in turn starting with #1.
Follow the Serial print instructions which involve first doing a Tare with no load applied, then add a known load & enter the weight in grams.
The firmware then calculates the appropriate calibration value & stores it in EEPROM.
When calibration is complete, the unit goes into measurement mode.
Upon subsequent start-up the unit should detect that calibration has already been done, so will go straight to measurement mode.
If you start up with a load applied, the unit will Tare to the model weight, so you need to start with no load.
Tare can be achieved by cycling the power or via the PC Serial link - enter "t".
Recalibration can be achieved via the PC Serial link - enter "r".
The attached sketch removes the need to run the separate Calibration sketch.
Just unzip the file into the Arduino sketch folder to get a new folder called CoC_Measurement_2Cell_2C. This folder will contain the sketch .ino file.
You will see a low memory warning in the IDE when compiled, but it seems to run ok.
As with the previous sketch, there are 3 variables which might need to be amended to suit your setup.
d1 is the distance between the wing LE & the front load measurement point, d2 is the separation distance between the two measurement points. You may also need to change the I2C LCD address to suit your unit. If you can see anything on the display, but all looks ok on the Serial output then run the I2C sniffer sketch to check what address is detected.
I have a 4 loadcell version nearly ready to go but first need to replace a duff loadcell before testing. This version will need the Arduino Nano Every variant which has more memory resources but will provide a more stable measurement platform for large/heavy models.
Re: DIY CoG Meter
Posted: 13 Jun 2021, 23:06
by Weds
Hi Peter
Did you get any further with the improved version, I'd really like to make this but if there's a better version in the pipeline I'll wait a while
Thanks..
Re: DIY CoG Meter
Posted: 14 Jun 2021, 07:35
by mjcp
(Following)
...as they say on Facebook
Re: DIY CoG Meter
Posted: 14 Jun 2021, 12:55
Okay guys
The replacement part allowed the unit to be completed a while ago, but was then put on the back burner after an initial check showed that it worked.
The pics below show the overall hardware setup for the 4 load cell version intended to cope with larger & heavier models.
Pairs of load cells are bolted onto 3D printed bases, connected together by three 6mm carbon rods which allow the spacing to be easily adjusted whilst keeping the bases parallel. The load cell amplifiers (smaller size ones) will just fit between the load cells & are covered by a 3D printed channel section. Two 6 way ribbon cables connect each pair of amplifiers to the processing unit.
I’ve used 10Kg load cells, but larger ones can easily be used if required without any other change as they all use the same mechanical interface & the calibration routine looks after the range values.
The processing unit is an ‘Arduino Every’ module which is very similar to the ‘Nano’ used in the 2 load cell version, but has the extra memory resources needed to cope with the extra variables used by 4 sets of load cell processing. The processor unit has connections to the 2 sets of load cells, the I2C LCD display and power (which can be either via the USB connector or via the ‘RAW’ input).
As can be seen from the photos, I have used 3D printed load cell mounts which accept 6mm carbon rods, topped by 3D printed levelling pads, the front ones are equipped to take LE reference pins.
My measurement points are 180mm apart, with the LE reference 50mm forward of the front measurement point, thus it is suited for wings which have a chord length of 250mm+. As for the previous version, these parameters can be altered to suit a different physical arrangement.
I have used 6mm carbon rods throughout, but in hindsight it may have been better to use a stiffer 8mm or so rod for the vertical stands, both to take the weight & minimise wing pad ‘spread’ (which will affect CoG location accuracy).
The 3D objects should be able to be easily modified to take larger rods.
Note that the load cell adapters were designed with a largish central open area to allow the bolts to be inserted.
The firmware is very similar to the 2 load cell version (just has 4 load cell sensing routines rather than 2) and adds the 2 front/rear cell load values together to arrive at the front & rear weights.
I have checked the CoG measurement by placing a known load on the stands & confirming that the load & CoG offset are correct. Not managed to put a large model on it yet though.
I will add a zip file containing the firmware and the 3D print objects, although this may now go into the relevant area in the Gold members section.
Re: DIY CoG Meter
Posted: 14 Jun 2021, 15:49
Arduino sketch and 3D print files attached.
(Note that the required I2C LCD & HX711 load cell libraries are those provided with the 2 load cell version sketch very near the beginning of this thread. There is also an I2C bus scanner provided there to identify your LCD address if needed.)
Note that the Arduino sketch will NOT compile for an Arduino Nano or even a UNO as it needs the extra memory resources provided by the 'Every' unit.
For the 3D print, you need 2off of everything except the Vertical Block Base & Balance pad where you need 4off.
As previously mentioned, the 3D print models currently have holes for 6mm rod. Rod lengths to suit your requirements, as long as the 4 vertical model support rods are all of the same length.
The holes for LE pins are 3mm.
I can provide a schematic if required, but the Arduino pin designations are stated in the sketch code.
Load cells arranged as #1 & #3 at Front, #2 & #4 at rear. Left/Right doesn't matter as summed.
Load cell#1 D_Out - Arduino pin 4
Load cell#1 SCK - Arduino pin 5
Load cell#2 D_Out - Arduino pin 6
Load cell#2 SCK - Arduino pin 7
Load cell#3 D_Out - Arduino pin 8
Load cell#3 SCK - Arduino pin 9
Load cell#4 D_Out - Arduino pin 10
Load cell#4 SCK - Arduino pin 11
LCD SDA - Arduino pin A4
LCD SCL - Arduino pin A5
0V/GND - Arduino 0V
Vcc - Arduino 5V
Input power either via USB connector or the RAW pin. Spec says 7-21V, but I would suggest a 15V or so limit.
Any queries/problems, please send me a PM & I will try to help.
Re: DIY CoG Meter
Posted: 14 Jun 2021, 20:54
by Weds
Brilliant, thanks for that Peter. I think mostly self explanatory. I'll send you a PM if I get stuck, unless it'll be useful to others..
Re: DIY CoG Meter
Posted: 06 Feb 2022, 10:42
by Jeff_Wezzi
Hi Peter,
Brilliant work, I am in the middle of building one and have a question for you that I cant seem to find the answer on google.
In your code you have the LE offset as d1=28 & d2 = 160, where on the load cells do you take the measurement's from?
Thanks
Re: DIY CoG Meter
Posted: 06 Feb 2022, 22:13
Hi Jeff, I see from the numbers quoted below that you are looking at the 2 cell unit
D1 is the distance from the wing LE reference pin to the point at which the front load is measured, whereas D2 is the distance from the LE to the rear load measurement point.
In each case I assume that the load is taken at the centre of my model resting pad above each cell.
The photo below shows one of my pair of load cells on the 4 cell unit. It shows the load cells & printed blocks into which are mounted 6mm diameter vertical rods which carry the model support pads. The load measurement points are assumed to be the centre of each pad, directly above the centre of the black blocks.
- 4 cell unit pair
Each load cell bar has 2 threaded holes at each end, the larger ones are for fixing to the base & the 2 smaller ones (adjacent to the load capacity/direction arrow sticker on the end face) are where the load is applied.
I have used 3D printed blocks on my 4 cell unit to support my measurement point above the centre point between the measurement hole pair, but the precise point only matters for a distance between multiple load measurement points.
The exact measurement point on the load cell isn’t critical as each cell is individually calibrated using a known weight, however the distance between the CoG reference point & each load measurement point are used to calculate the CoG distance from the LE Ref. point.
On the 2 cell unit, my LE Ref. point is 28mm in front of the front load measurement point & 160mm in front of the rear point, thus the load point centres are 132mm apart.
Hope this helps.
