Flying... easing of lockdown (England)
Posted: 24 Mar 2021, 09:53
by mjcp
As we [rumble, stagger, lurch, smoothly transition] (depending on your thoughts) towards some pivotal dates, 29th March, 12th April, 17th May etc, I have some questions as to where flying fits.
The BMFA's interpretation was, I feel, flawed in suggesting we can fly now, as the "stay home" rule is still in effect (England) and with the best will in the world, our hobby is hardly exercise!
From the 29th March, that is removed, but what impact for some of the events listed for April? They are clearly outside and often on publicly accessible land... clearly we cannot meet sociably as that could easily break the "rule of 6", but what happens if we show up somewhere and there's some other like minded aviationists (staying a wing span from one another
12th April seems irrelevant, its the pubs opening gardens and not much else relevant to us and hills.
17th May seems to be the one: events outdoors with up to 30 people. Will we need a booking system to attend an event between 17th May and 21st June?
What about a trip to Rhossili or Bwlch? It seems the regions are a little out of sync on some rules and not so clear on cross boarder travel: If wales allows us in, going from England to Wales could still break the English "no foreign travel" rules...?
More info (England)
https://www.gov.uk/government/publicati ... d-29-march
Re: Flying... easing of lockdown (England)
Posted: 24 Mar 2021, 11:10
by simon_t
The significant change earlier in March was that ‘recreation’ was added as a reason to be able to leave home (although you still needed to stay local). So you were then allowed to fly locally on public sites (clubs were not allowed to open).
April 12th relaxes the rules on gatherings, so events such as the GPS triangle training at Buckminster near the end of April will meet the proposed post-April 12th rules. It is all there in the government guidance, but sometimes needs to be re-read a few times to get the subtleties.
Posted: 24 Mar 2021, 11:27
by Ian Davis
The BMFA site is clear, with a little bit of wishful thinking:-
Outdoor sports
grounds and facilities (which includes model flying club sites) remain in the list of business/services that must remain closed.
The projected date for re-opening is March 29th, and will not be subject to the gatherings limits, but should be compliant with guidance issued by national governing bodies.
Ian
Posted: 24 Mar 2021, 11:48
by simon_t
The key thing for the weekend events we do (Aerotow, GPS Triangle), is that staying away from home overnight is only proposed after 12th April. This is one of the ‘subtleties’ that is no so clear on the gov pages - you have to look at the detailed stuff to see that permission.
Posted: 24 Mar 2021, 12:13
by mjcp
ian davis wrote: ↑24 Mar 2021, 11:27
Outdoor sports
Ian
"outdoor gatherings (including in private gardens) of either 6 people (the Rule of 6) or 2 households will also be allowed"
Sounds like a restriction on gatherings is still in place 29th March onwards.
Posted: 24 Mar 2021, 12:17
by mjcp
simon_t wrote: ↑24 Mar 2021, 11:48
12th April, Rule of 6 still in force, but you *CAN* stay away if: "Self-contained accommodation such as campsites and holiday lets, where indoor facilities are not shared with other households, can also reopen."
Posted: 24 Mar 2021, 12:18
by mjcp
Long and the short of it, seems like April's **organised** events are stuffed. Concur ?
Posted: 24 Mar 2021, 17:35
by simon_t
mjcp wrote: ↑24 Mar 2021, 12:18
No - I don’t think you are looking at the detailed rules - only the summary - dig deeper on the website. There is a statement along the lines of for organised sporting events the numbers are unlimited - the rule of 6 does not apply.
Posted: 24 Mar 2021, 21:06
by mjcp
Here’s the act of parliament. Step 2 from 16th April. Rule of 6 applies to outdoor gatherings.
https://www.legislation.gov.uk/uksi/20 ... le/2/made
Participation in gatherings outdoors
2.—(1) No person may participate in a gathering in the Step 2 area which—
(a)consists of more than six people, and
(b)takes place outdoors.
(2) Sub-paragraph (1) does not apply if any of the exceptions set out in paragraph (4) or (6) apply.
Step 3 as above but allows 30 to meet outside.
https://www.legislation.gov.uk/uksi/20 ... le/3/made
The sports exception you mention is there as follows (from para 6 mentioned above):
Exception 3: outdoor sports
(5) Exception 3 is that the person concerned is participating in an outdoor sports gathering.
So, we might get away with an organised, timed and scored f[x]f comp, but unlikely to get a typical scale meet interpreted as a sports event, though to be fair, both are lacking in several of the requirements to be “sports” in the definition used by sport England to argue bridge is not, but darts is!
Posted: 24 Mar 2021, 21:45
Marc,
At the end of the day, it all depends what the BMFA/LMA says is allowable at each stage as it is usually their insurance that we fly under.
Therefore the only sure way is to wait & see as & when the guidelines change.
Posted: 25 Mar 2021, 19:23
Limited flying has resumed uphere in the frozen north. Here is a statement from our national body the SAA.
"SAA statement from 12th March 2021
Due to the slight easing of COVID restrictions by the Scottish Government, the SAA are delighted to announce that as from Friday 12th March, R/C flying in groups of no more than 15 may recommence on the proviso that the below document entitled: COVID Sports Specific Guidelines for the Scottish Aeromodellers Association Rev 7-dd446 is fully adhered to. This is in draft form at the moment but I am happy that if the guidelines detailed in the document are followed, then we will be good to go. Any further relaxation of the restrictions will be communicated in the same way.
Enjoy and Happy Landings
Steve McDonald. SAA Chairman.
I generaly fly alone or with one other soarer on my local hill. There is plenty of room for a further 13 guys if you wish to travel north.
Posted: 26 Mar 2021, 14:55
by FrankS
Peter Balcombe wrote: ↑24 Mar 2021, 21:45
Marc,
Peter, the BMFA has already clarified that the insurance is still valid regardless of the COVID regulations, so although you may be breaking Covid rules by going flying, meeting more than 6,etc if you were make a claim on the insurance it would be covered
Posted: 26 Mar 2021, 15:31
FrankS wrote: ↑26 Mar 2021, 14:55
Marc,
Thanks Frank. I had forgotten that
Posted: 26 Mar 2021, 20:00
Posted: 27 Mar 2021, 09:15
But still socially distance!
- distance.png (89.4 KiB) Viewed 1735 times
