wing with simple capstrips
right wing covered in DIACOV
Hi Tony,
what paint are you using on the Diacov? I am thinking of using Diacov on a 1/5th scale Mucha standard and I need to either match the white of the Diacov to paint the fiberglass fuselage or paint everything.
Rob
Rob
Hi Rob,
I am using spray cans, the one on the left is primer/filler
the one on the right is "signal-white"
The paint is more expensive than car-paint, but at least the
white paint covers better!
procedure: clean diacov with alcohol, spray with primer, sand
gently with 400 paper, spray with paint
Tony, 400 grit is a bit coarse for the primer, especially with an air-dry paint: better off with 600 or 800
While finishing the other wing, I get back to posting pictures of the fuzz-build
5x3mm spruce stringer steamed to conform tail and glued into formers 6 & 7
5x3 spruce stringers with 5x3 spruce spreader bars
front end stringer steamed to shape
front part stringer glued to all 4 mm braces
top stringer glued and reinforced The fuzz structure is very light and very
stiff with respect to bending and torsion
