TonyL
Post by TonyL »
plywood covered side faces hinges
TonyL
Post by TonyL »
pre-shaped 0.4 mm plywood covers the aileron leading edge
TonyL
Post by TonyL »
2mm piano wire epoxied into 2mm balsa false leading edge
TonyL
Post by TonyL »
2mm trangular ribs for the airbrake, 0.4 mm plywood ironed on, reinforcement for the drive arm
TonyL
Post by TonyL »
1.5 mm dural drive arm epoxied into place at roughly 45 degrees
TonyL
Post by TonyL »
4 mm leading edge sanded round
TonyL
Post by TonyL »
finished airbrakes light and stiff! 8 grams/piece
TonyL
Post by TonyL »
1.5 mm plyrib reinforcement to take micro-servo
TonyL
Post by TonyL »
rib reinforcement with servo
TonyL
Post by TonyL »
air brake installed, servo installed (top view)
