Schleicher ASH31 4m
MartinE
Re: Schleicher ASH31 4m
Post by MartinE »
Meanwhile I'm putting together the wing-joiner.
This will have 2 carbon/Kevlar ballast tubes built-in (For steel rods, giving weight and strength) - photo.
These will be wrapped in a uni-direction carbon she'll.
Tubes and steel rod
Tubes and steel rod
MartinE
Post by MartinE »
The tubes are bonded together, leaving a trough in between.
This is filled with several lengths of 12k carbon tow (infused thoroughly with epoxy resin) and lightly clamped onto the wing-joiner jig.
When that's cured this can be repeated on the other side.
MartinE
Post by MartinE »
While the resin was curing, I made the tail-plane profiles ready for foam cutting.
3mm ply, profiles printed and then glued on with 3m 75, cut out on the fret saw.
MartinE
Post by MartinE »
I got a bit side-tracked from the wing joiner, and cut the elevator foam cores.
These are cut from XPS foam (the old blue foam). I used this for a couple of reasons:
1. The higher compression vs EPS allows me to use a thinner skin (than the obechi) & so allows me to fit a thin wing servo inside the profile.
2. I can also then apply a live Kevlar hinge
It didn't go entirely to plan, with the hot-wire, so had to do some sanding afterwards.
MartinE
Post by MartinE »
Still putting off the wing joiner!
This time it's the fuselage - sprayed on a light coat of 3m 75, then smoothed on the 100gsm twill glass fibre.
How exciting!
I'm really interested in how many layers of glass you'll add to the inside/outside, and which gsm values?
I asked around when I was making a lost-foam fuselage and the experienced builders suggested that for a 1/3 - 1/4 scale glider they'd use a total of around 800-1000gsm for the nose and 600-800gsm for the boom. With the balsa core approach you've used, I assume you're using a lot less glass?
Thanks for posting your build thread Mark. I've found it very informative.
Also...as an aside, I noticed what looks like a slim home-made carbon fibre fuselage on your workbench, and I wondered if you'd used carbon fibre braid to cover it? I moulded a tail boom this morning using carbon braid over a male plug, and it seems to have gone really well. I found that pulling the braid at each end made it tighten beautifully around the plug - like those Chinese finger traps.
P.S. I'm sure it's not just me that scrutinises photos of other people's workshops. Err. Is it? :oops:
MartinE
Post by MartinE »
Hello Rog,
The ASH31 is still TBD, probably 1 more 100gsm up front & carbon fibre on the rear. That skinny bit by the fin will have some more added.
The fuselage in the background is another experiment - balsa rear with 110gsm carbon skin (not a tube, never used it), front in glass over shaped foam (to be removed later) - I digress😀
You have plenty going on in your workshop!
If I could make a suggestion about the narrow boom just in front of the fin (where most T-tail models snap). Carbon, although it has a very high Young Modulus and excellent strength to weight, is also very brittle and therefore prone to failing under the kind of shock-load experienced in a boom during a rough landing. For these stress-points, I've switched to aramid fabrics like Kevlar and Diolen. They have incredible tear-strength, so prevent the boom splitting, and allow a little flex so that the structure as a whole can absorb the stress as it bends.
I made a boom last week using two wraps of 200gsm Diolen plus 1 x 200gsm glass and I when I load-tested it in bending I could not break it, even at the 30mm diameter section. Out of curiosity, I took it out the test jig and tried to break it over my knee (and I'm a huge bloke) and I still couldn't break it! Also, Diolen is way cheaper than carbon and a much lower health hazard to work with.
MartinE
Post by MartinE »
That's a very good point Rog, I recall reading they have a similar strategy for the cabin crash structure on full size gliders.
I have some 100gsm Kevlar so will use that. The fun will be avoiding sanding into it and getting fuzz. Perhaps a layer of glass on top - food for thought.
