Schleicher ASH31 4m
Re: Schleicher ASH31 4m
Outer wing wing joiners bonded into the inner wing sections - all the pins line-up and move smoothly (phew, no faffing around to be done).
You can just see the white wire conduits, in their slots (Thanks for that suggestion Kenneth). I think I'll fill the gap with some balsa, then sand smooth.
Note that all the wing joiners are mounted in between the upper & lower spar caps.
Wing top surface bagging:
I decided in the end to use Mylar (as I already had it).
First photo shows pre-primed Mylar (rolled up), tissue paper, breather fabric & 106gsm carbon fibre (bias).
I used a roller to apply the resin, this gives even distribution and does not move the cloth.
Using the tissue paper, instead of 25gsm glass was much easier (Thanks again Kenneth).
And the into the bag for 18hours.
What I didn't show was the wing foam negatives top and bottom, fully weighted down.
The wings came out of the bag this morning and (as expected) they're certainly not moulded wing smooth, but definitely my best bagged wings. Still some slight dips and ripples.
The tissue paper has eliminated any pin holes, which is great.
On to the underside shear webs, spar caps, etc.
On to the undersides;
2 slots are cut, down to the top spar cap - 1 straight & 1 wavy. Resin is then injected into the slots and then pre-cured/trimmed lengths of bias carbon fibre are slotted in.
The wave should give compression and shear strength.
The spar caps, from carbon tow (and resin), are then laid on top.
The wings are then bagged.
While the wings cured, i started on the tail servos. Both tucked inside the vertical tail.
Holes cut either side of the rudder mount and the foam dig out. Then 2 mounts made that allow me to install servos from the rear.
Good progress Martin; I am glad my tissue paper idea worked for you.MartinE wrote: ↑07 May 2022, 15:25 On to the undersides;
Interesting shear web set-up. Did you borrow the wavy shear web idea from James Hammond who includes it in his designs? I am not convinced yet; if forced to cut two shear web slots I would choose straight cuts at the front and back of the spar cap to make a (torsion) box spar.
How did you cut the slots to the top spar? Any interesting jigs and tooling or just by hand?
Kenneth
Hello Kenneth,
Sorry for late response, been having issues posting & now away on holiday.
Yes the idea was from Mr Hammond. Works very well.
Martin
Martin
Yes I did think about a way to cut since wave slot, but to be honest, just did it by eye.
Not sure how much difference an accurate done wave cut would make.
