Schleicher ASH31 4m
MartinE
Schleicher ASH31 4m
Post by MartinE »
The Schleicher ASH31 is an elegant modern glider, one which I fancied making. There are no plans commercially available, so set about creating my own.
My workshop space is limited to a max wingspan of 4m, so plumped for the 18m variant at 1:4.5 scale.
Having drawn up all the fuselage formers, SLEC UK did a quick and quality job of CNN cutting them.
Wings will be bagged blue foam with carbon fibre spars.
MartinE
Re: Schleicher ASH31 4m
Post by MartinE »
Here are the plans I'm working to....
ASH31 310_00_9001.pdf
(43.11 KiB) Downloaded 291 times
ASH31_plan 4m 081021 Layout1.pdf
(155.59 KiB) Downloaded 281 times
MartinE
Post by MartinE »
...here is a plan without having to download
Elliot Howells
Post by Elliot Howells »
ooh, watching! It's not often a glass glider is modelled like this, good for you.
MartinE
Post by MartinE »
Thanks Elliot. I made an ASW15 like this ( from someone else's plan), I glasses the skin and painted which gave a smooth effective finish.
Here's my third attempt to post the plan drawing.
MartinE
Post by MartinE »
The first pictures were of the initial dry assembly. I've attached some glued pictures. Note the cheap laser level I used to line-up the main fuselage formers.
I'm with Elliot on this one Martin. I will watch this build with interest.
MartinE
Post by MartinE »
Welcome Brian, I'm full of early build enthusiasm, so completed a bit more today, whilst ensuring still remaining straight.
I've used my block plane to trim the spruce stringers, before fitting. Certainly easier than widening former slots.
Central section, around the wing mount pretty strong now.
Looking good Martin.
Following with interest :)
MartinE
Post by MartinE »
Just noticed you're from Clevedon, Peter - i grew up in Congresbury - small world.
