Schleicher ASH31 4m
MartinE
Re: Schleicher ASH31 4m
Post by MartinE »
Final decision on the tail boom:
1 layer if 100gsm Kevlar at 45deg
4 lengths of 80gsm uni-carbon
Final layer of 50gsm glass, to lay down all the rogue Kevlar fibres
SedB
Post by SedB »
No idea, but guess that's well enough for belly landings!? :)
How easy/difficult was is to place the 100gr glass. All I uses so for was 50, and that I already found a bit of a pain in the corners..
Guess the fun job still has to come; sanding it all smooth? I'm curious what other treatments you'll for the fuselage covering (sanding, filling, priming).
Looks really nice so far!
Daniel
MartinE
Post by MartinE »
Hi Daniel,
It feels pretty strong now. Now I need to remove some of the bumps and then fill and sand (as I did to the bottom).
The 100gsm glass is relatively easy to lay on a large fuselage like this. Spraying fuselage with a light coat of 3M 75, before laying, makes the resin application a lot easier, as the cloth does not move.
NSWanderer
Post by NSWanderer »
MartinE wrote: 04 Jan 2022, 16:16 Spraying fuselage with a light coat of 3M 75, before laying, makes the resin application a lot easier, as the cloth does not move.
That's a great trick - thanks!
MartinE
Post by MartinE »
In order to get the desired nose fit, I bought the GM spinner and 17x10 scale blades.
These are designed to fit the shape of the fuselage (and are already coloured white, obviously :D ).
Whilst not cheap (£60 for spinner & colet), they very well made, with the spinner in carbon fibre.
MartinE
Post by MartinE »
To create the tail hinge, a carbon tube was glued into a slot in hard balsa, which was then glued to the fin, then shaped.
MartinE
Post by MartinE »
2 fibre glass tabs were made (with a corresponding hole) then bonded into the tail.
Then the rod can be run down the tube, through the tabs to form the hinge.
NSWanderer
Very neat, Martin.
Please do not post on this Forum for the next 7 days (Approx).
The Forum is being moved to a new server, and your posts will be LOST forever
Thanks for your help.
MartinE
Post by MartinE »
Hope it's safe to post now.
