Page 2 of 2
Re: Airfoil choice
Posted: 14 Dec 2021, 21:51
by Antonia
Thanks John, that would save a lot of head scratching for sure. Thanks for your reply Roo, if you could let me know your thicknesses at what station that would be great
Re: Airfoil choice
Posted: 14 Dec 2021, 22:53
by LarsWikstrom
I have seen some post with someone tuning what can be likened a cnc wire cutter. Something like that would enable a change in cord along the wing. Just an idea.
Re: Airfoil choice
Posted: 15 Dec 2021, 07:49
by Antonia
Hi Lars, the wing cores are certainly going to be a challenge, I have a couple of ideas rattling around in my head
This is a coming closer to retirement project to ward off the
”biscuit crumbs and dribbling from the corner of my mouth moments”
I have an inquiry with someone who has a CNC hotwire cutter, just waiting for them to comeback to me to discuss further, failing that I’ll knock up a gravity feed system with a shed load of templates.
Re: Airfoil choice
Posted: 16 Dec 2021, 06:42
by LarsWikstrom
That sounds great and very interesting to follow.
Re: Airfoil choice
Posted: 16 Dec 2021, 17:10
by roo Hawkins
Hi had a look at my templates. Most of the wings is hq 2.5 12 the last 3 ft going to hq 2.5 10 . root for about 8in in has a modified section that is thicker for the wing joiner. The full size is the same I think.that's a 7 meter span The ritzy is to old school it's ok for a 4 meter glider with foam veneer or built up wing where you need a thickness for strength. It's a bit draggy compered to hq.. on my vintage gliders I use hq 3 .hqw.2.5 12 is the best foil I have found for glass gliders.
Re: Airfoil choice
Posted: 16 Dec 2021, 19:44
The new 1/4 scale PT Salto wing uses HQW2.5/12 & seems to fly well according to Cliff.
Presumably he aerobated it as well as general flying at Sandhays.
