CM 8/13
Re: CM 8/13
Pat,
3 x 10 would be a better description.
:D :D :D :D
john greenfield
Re: CM 8/13
Post by john greenfield »
patte de loup wrote: 11 Jan 2022, 20:21
john greenfield wrote: 11 Jan 2022, 09:34
patte de loup wrote: 02 Jan 2022, 17:28 Now, is time for planking with 30/10 balsa sheet of the upper side .
Patte
Can you explain what 30/10 balsa is please?
John,
I cut strips of 10 mm width from balsa sheet of 3mm thick for planking the fuse. Same method for making a hull of boat.
( sorry my english is little poor )
Thank you Patte. 3mm x 10mm makes much more sense. I have seen this annotation on several European plans but never really understood what it meant.
patte de loup
Re: CM 8/13
Post by patte de loup »
John,
Just for clarification.
The x/10 annotation on french drawing or Europeen means the thickness of the wood:
- 30/10 = sheet of wood of 3 mm of thickness and is not depending of the type of wood.
Sometimes it's seems " bizare " to 100/10 , which means 10 mm of thickness !
Pat'
Re: CM 8/13
Please do not post on this Forum for the next 7 days (Approx).
The Forum is being moved to a new server, and your posts will be LOST forever
Thanks for your help.
patte de loup
Re: CM 8/13
Planking is finshed and it's time for sanding
patte de loup
Re: CM 8/13
Nose and parson's nose need to be done
patte de loup
Re: CM 8/13
Nose was added and fuselage back was shape .
Complete sanding of fuse was also done for having smooth surface before recovering it with fiber glass in 2 layers (160g/m² & 80g/m²)
patte de loup
Re: CM 8/13
Next hard work comes, apply filler and sand several time for reaching a glossy surfage of the fuselage which will be a master.
A new step is coming, build the mold of the fuselage... a new challenge
patte de loup
Re: CM 8/13
some news about CM8/13 progress : mold is done
patte de loup
Re: CM 8/13
second part ;)
