CM 8/13
CM 8/13
I have started my new acrobatic glider last April, hopping it will be finished in next May for the annual GPR meeting in Menez Hom. Huge challenge when, you are still in activity and normanlly I make 2 years for building one
The real one is stored at Anger Macé Museum and mine will be at 1/3 scale with 4.5 meter of wingspan
Pat'
Pat'
Re: CM 8/13
Frames are now on the primitive jig and stringers are on going for glueing ( pin 8 x 8 ).
Re: CM 8/13
Nice looking glider, Pat, not seen that one before...
Re: CM 8/13
The fuse is enough strong to be remove from the jig and move on to lower side
Pat'
Pat'
Re: CM 8/13
Pattepatte de loup wrote: ↑02 Jan 2022, 17:28 Now, is time for planking with 30/10 balsa sheet of the upper side .
Can you explain what 30/10 balsa is please?
Re: CM 8/13
John,john greenfield wrote: ↑11 Jan 2022, 09:34Pattepatte de loup wrote: ↑02 Jan 2022, 17:28 Now, is time for planking with 30/10 balsa sheet of the upper side .
I cut strips of 10 mm width from balsa sheet of 3mm thick for planking the fuse. Same method for making a hull of boat.
( sorry my english is little poor )
