Wing joiner
JamesH
Wing joiner
Post by JamesH »
Evening I'm building a Scheibe-Loravia Topaz the plan uses a 14mm graupner steel bar & brass box which is like rocking horse 💩.
I can source 12mm and 15mm but what would everyone recommend. Many thanks
Re: Wing joiner
James, you can't get the 14mm any more. The 15mm will be fine, just adapt the ply support accordingly... (Note the brass box is 16mm)
JamesH
Re: Wing joiner
Post by JamesH »
chris williams wrote: 05 Jan 2022, 20:34 James, you can't get the 14mm any more. The 15mm will be fine, just adapt the ply support accordingly... (Note the brass box is 16mm)
Thanks for that, as I'm not 100% sure are you the same person as the designer ?? If so ive got 1 more question about the F6a retro fit
Re: Wing joiner
Post by Trevor »
Quick Chris - deny everything! 🤫
Re: Wing joiner
No prob James, fire away...
Re: Wing joiner
Trevor wrote: 05 Jan 2022, 21:55 Quick Chris - deny everything! 🤫
He never learns.....
8-) 8-) 8-) 8-)
JamesH
Re: Wing joiner
Post by JamesH »
:lol: :lol: :lol:
Barry_Cole wrote: 05 Jan 2022, 23:23
8-) 8-) 8-) 8-)
JamesH
Re: Wing joiner
Post by JamesH »
chris williams wrote: 05 Jan 2022, 22:14 No prob James, fire away...
Ok on the plan I've got f6a is a piece which is angled in front of former f6 but I've seen a different set of plans where there's a f6a former between f6 and f7. I'm not sure if it should have one there's definitely not one in the laser pack just wondering if it's been missed off by sarik or just not needed cheers.
Re: Wing joiner
First up, James, have you had all the build pics from me...!
JamesH
Re: Wing joiner
Post by JamesH »
chris williams wrote: 06 Jan 2022, 09:51 First up, James, have you had all the build pics from me...!
Yes I have
