I have just started building Chris Williams 1.4.2 scheibe-loravia topaze and I am struggling to find a supplier of 4mm x 6mm half round wood, anybody know of a supplier of this?
Many thanks
Rob
3mm x 6mm half round wood
- Trevor
Re: 3mm x 6mm half round wood
I plan to build the Topaze too, and, in the absence of any suitable half round mouldings, have bought some rectangular sectioned basswood for the stringers/longerons with the intention of rounding them off before fitting. At least, that’s the theory. . .
www.bartonhewsons.uk
The stuff I have used for years was made from Ramin. However, the man at the timber shop reckons it's a protected species now, which is why it seems to have disappeared... Triangular strip might do the job: it just needs to simulate the metal tube stringers of the full-size...
Hi Chris,
Thanks for the reply, I have just a model boating friend put me on to www.cornwallmodelboats.co.uk, they can supply half round walnut in the right size, might use that.
Many thanks
Rob
Many thanks
Rob
You could always run a dowel through the bandsaw!
Rob if you havent got a band saw im happy to cut it for you .
Keith
Keith
Hi all
I have sorted the half round dowel, made a small jig for my scroll saw, dowel now cut in half.
Many thanks for the suggestions and offers of help.
regards
Rob
regards
Rob
- Trevor
Glad you’ve found a solution,Rob. Are you going to do a build thread for your Topaze? Hint, hint
I bought some 6mm x 3mm ‘almost’ half-round stripwood from B&Q. It looks and works fine on my Topaze
