Rubber or elastics to doors
Posted: 19 Apr 2022, 19:12
by LarsWikstrom
Hi,
To my 1/3 SHK, I need to find a solution to closing the doors on the landing gear. I have hooks on the doors and on the former.
I had black nylon covered elastic bands but they turned out to not provide enough flexibility and hindered the gear from coming down.
What would you recommend?
Thanks, Lars
Re: Rubber or elastics to doors
Posted: 19 Apr 2022, 21:34
by Trevor
A micro servo and a sequencer (either onboard or in the Tx) saves a lot of faffing around with elastic.
Posted: 19 Apr 2022, 23:28
Posted: 20 Apr 2022, 10:12
Permanently spring-loading the u/c doors can be achieved by the use of fine piano wire torsion springs...
Posted: 20 Apr 2022, 19:03
by catwok
On my Libelle I put the doors in position and held them in place on the outside of the fuselage with masking tape. Making sure you tape the length of the hinge line. Then on the inside of the fuselage I masked about 20mm either side of the hinge line. Then smear on some good quality silicone. Remove the tape on the inside of the fuselage first, and then the tape on the outside when the silicone has set. The elasticity of the silicone is strong enough to close the doors and makes a nice neat hinge line on the outside. Very easy to repair if it gets damaged. Thanks Elliott for the idea...
Posted: 20 Apr 2022, 19:51
by LarsWikstrom
Many thanks for all suggestions. The concept of silicon sounds very good as it also removes the gap and with that turbulence.
I think I will try that.
Thanks, Lars
Posted: 25 Apr 2022, 17:29
by Keith
Lars sent you a PM.
Keith
