Infant Optics DXR-8 Best Baby Monitor System Review
The Infant Optics DXR-8 is currently one of the best selling and most trusted baby monitoring systems on the market at the moment. Thanks to its high image quality and all of the essential functionalities of a best baby camera monitor like night vision and two-way microphones, many parents have had sounder sleep at night knowing their children are under constant supervision. The fact that it is quite affordable also helps sweeten the deal for this baby monitor camera.
In this article, we’ll go through the most important information about this monitor system that you should know before you buy.
See Also: Top rated video baby monitors
Filled With Useful Functionalities For Parents
The DXR-8 has beautiful image quality and there is little delay between video and audio signals. This is the biggest selling point of the system, you’ll have less interference or technical troubles to deal with while using the monitor.
The camera unit is also equipped with night vision capability to help parents track their baby in the dark. The two-way talking system allows you to converse directly with your baby and the baby to speak back to you when needed.
The lenses are interchangeable and by default, the camera unit will already be equipped with a zoom lens when you first unbox it. Although a wide angle lens is superior because it gives you a fuller view of the nursery, if you want to have this lens, you will need to buy it separately.
The system also has temperature sensors to make sure the ambient in the nursery will always be at a nice room temperature.
The security camera that acts as your eye is also very portable and can be brought around the house when needed. If you mount the camera to the wall, there’s a wall mount that you simply need to drill into the wall to hang it up.
Long Range And Secure Wireless Signal
Because this is a traditional baby monitoring system, there’s no smartphone app. Instead, everything must be controlled via a dedicated parent unit.
The monitor operates on a secured 2.4 GHz FHSS frequency that has a fairly long range. In our tests, the parent unit can still pick up HD video around the house and even out on the yard. The camera is not connected to the Internet, so there’s no need to be afraid of Internet-based hacking that can compromise your family’s security and privacy.
Simple Set Up
The setup process for this the best baby monitors for baby are straightforward. They will only take five to ten minutes to unbox everything and set them up. Since they don’t use WiFi, which tend to be problematic in the pairing process, linking the parent unit and the monitor system together are considerably less painful and quicker overall.
The toughest part of the setup process is linking the Li-Ion battery to the monitor. Don’t fret too much about this part, though, as long as you follow all of the instructions provided in the user’s manual, you’ll get it down in a few minutes.
We recommend that after you’ve set up the baby monitor to go through all of the settings in the system. Try to discover and test out all of the extra functionalities that it has, like the “Sleep Mode Delay” setting.
Conclusion
The Infant Optics DXR-8 must definitely be one of the best baby monitors on the market for the money that you can get at the moment. We hope that this article has been of use in providing you with important information you need before you make a purchase decision.
Buy plywood
Buy plywood
Re: Buy plywood
Avon Plywood in Bristol UK.
