Graupner G103
farleymartinez
Graupner G103
Post by farleymartinez »
How to choose the best vacuum cleaner for your home?
Vacuum cleaners are considered an effective assistant for every famiy alnd are extremely popular today. As consumer demand increases, more and more brands of vacuum cleaners are born.
So to choose the Best Vacuum Cleaners, you can refer to our article.
What is the best vacuum cleaner?
It is the type of vacuum cleaner with capacity, filter, a design that best suits the house’s structure and the purpose of use and your pocket. So, you need to determine the main needs and space you use the vacuum cleaner to make the best choice for you and your family.
There are several types of vacuum cleaners on the market today, such as corded, cordless, or robot vacuum cleaners. However, they all share some important factors below for you to consider before buying a vacuum cleaner.
Some criteria you need to know
1. What is the surface you want to clean?
Evaluate the surface or item you want to clean. If you’re going to clean complex equipment such as ceilings, ceiling fans, under beds, etc., this requires a specialized vacuum cleaner such as a vertical machine or a robot vacuum cleaner.
2. Dustbag
Some models have a dust bag or not. There are many different dust bag materials such as:
  • Paper bags: when the dust is full, you can throw it away and replace it with a new bag.
  • Fabric bag: removable and washable for reuse.
  • Magnetic bag: can prevent scrap when sucked in.
  • High-quality material bag: absorb odor, antibacterial, and filter dust.
If your family has people prone to allergies or asthma and are worried about the indoor air, choosing a vacuum cleaner with a bag will be better.
3. Dust extraction capacity of the machine
The most important criterion for choosing a vacuum cleaner is the vacuuming capacity of the machine, which is different from the machine capacity.
Machine capacity is an indicator showing the power consumption of the vacuum cleaner.
The vacuum capacity is the power that shows the vacuuming ability of the machine; the higher the vacuuming capacity, the stronger the suction power, the more effective the vacuuming ability of the device.
4. Filter
Some vacuum cleaners do not have a high-level dust filter function, and fine dust particles can pass through the vacuum cleaner and re-enter the room air.
If in your family there are members with asthma, allergies to fine dust particles, etc., you should use a vacuum cleaner with a filter.
5. Brand and Origin
You cannot compare the quality and durability of a mass vacuum cleaner in the market with a company specializing in high-quality production.
Find out more about the manufacturer, and it is best to have a warranty for the vacuum cleaner you buy. Besides, you should see Best Rated Vacuum Cleaners of many different brands to get the most honest view of the type of vacuum cleaner you want to buy.
6. Other Features
Full machine dust indicator: helps you control the machine’s operation and dump the dust when full.
  • Blowing function: suitable for houses with gardens.
  • Rotating suction head: helps you conveniently clean tight corners, jammed corners.
  • Height-changing: makes it easy to vacuum in high, hard-to-reach places.
Hopefully, some of the factors we offer will help you choose the best vacuum cleaner brands for you and your family. I hope you always feel comfortable with clean air in your home!
