1:4 Scale 5m Horton III designed by Jilles Smits
Fans and Thermals.
Rich vale
Post by Rich vale »
This is from Laser Cut sail Planes and is a real builders model.
Rich vale
Re: 1:4 Scale 5m Horton III designed by Jilles Smits
Post by Rich vale »
I going to start will the center section and then build the wings from that.
You need a bigger bench Rich.
Rich vale
Post by Rich vale »
Started center section top sheeting. Wheel gondola formers removed to allow center section to sit flat on building board.
Rich vale
Post by Rich vale »
Sheeting continuing and drive shaft install
Rich vale
Post by Rich vale »
wing constrution started with joiner tubes anbd spars
Rich vale
Post by Rich vale »
Lots of ribs
Lawrie P
Post by Lawrie P »
Hi Rich,
Watching this build with interest from down under in Oz.
Keep those photos coming along.
Lawriep
Rich vale
Post by Rich vale »
First wing released from center section, assembled and sheeted on top surface. Each wing panel is 2500mm long from cernter section to tip.
Rich vale
Post by Rich vale »
Control surfaces removed from wings and completed
