Wing joiner location
AdamChambers
Post by AdamChambers »
Im converting a design from flat steels to round tube .
The design in question, a airspeed tern has flat steels in between the front and rear spars. Its over engineered and heavy as a result.
Can I locate an alternative single round joiner tube arrangement central in the wing? I will provide suitable reinforcement, although the ribs in question are ply and have incidence pegs.
Should I be placing the joiner over the centre of pressure /cg?
Re: Wing joiner location
Adam, there was 3.5 scale Petrel at the last WS scale meet which had a moderately heavy landing on the front of the slope. It had been modified from flat steel to a round joiner. The joiner stayed where it was, while wing re-modified itself around the joiner, resulting in a really difficult-looking repair.
A flat steel joiner would have simply bent forwards, allowing the the rubber bands to do their work. How do I know this? I've had more heavy slopeside landing with my various Petrels than I care to talk about...!
I really would not change the joiner. You do not need to " save waight" the model is proven as it is. Chris's description is very accurate.
AdamChambers
Cliff,
It is mighty heavy . Formers alone are 1kg. Massively over engineered . Ive recut lighter ones .
Both blades are 750mm long and again add a lot of weight.
Barry who built one on here recommended it needs lightening after flying it.
AdamChambers wrote: 21 Aug 2023, 20:49 Im converting a design from flat steels to round tube .
Don't do it........
What span is the model, and the projected all-up-weight...?
Post by Trevor »
I'm all in favour of a bit of weight saving but I'd leave the joiners alone and focus on the rear end. Generally the rear fuselage formers are a good target, and I tend to go for balsa skins rather than ply. Tailplane joiner wires often seem rather on the heavy side, unless you are contemplating high speed, high g aerobatics of course.
Each to his own, I suppose,
There is nothing wrong with the weight of the Tern. The models that have been built fly well. I think they have all turned out at around 11-12 lb which is not bad and about average for a 1/4 scale model with a span of 4mtr.
Next question: which depth of blade; 12mm or 15mm...?
AdamChambers
Weight saving operation has already commenced . 5kg is the target , 1 kg below barrys build.
Overall the drafting quality is a 4/10 when it comes to the formers. Ill end commentary there as this isnt the reason for my query.
Chris, 4m span , taper wing . 15mm steel and brass blades x 2.
The rear spar is on the centre of pressure so maybe a tube can go there instead of a blade with a short blade up front ? Barry friend did the opposite way round and seems to be happy with it.
